wheel spacers
Old 03-15-2018, 08:21 AM
S2Bray's Avatar
Default wheel spacers
I like the idea of fitting some spacers, to widen the track and give a more purposful stance, whilst retaining OEM wheels. So far so good...
Tegiwa supply some decent spacers with built in studs, and the OEM 17s have little relief pockets which will swallow up the original protruding stud.
My problem is this - I've also got a set or ropey old 16's, shod in winter thyres, which have proved pretty useful in recent weeks. These however don't have the relief pockets, so if I fit spacers, I'll either have to sack off the old winters OR remove the spacers once a year/every couple of years when the weather demands.
So I guess my question is this - is there anything I should be concerned about, treating the spacer like a removable item along with the wheels, rather than fitting (maybe Loctite-ing) and forgetting.
I know it will have an affect on the geo, but for those few ploddy winter weeks, I'm not worried about not having optomised geometry.
Old 03-15-2018, 08:46 AM
noodels's Avatar
Its not going to change camber, caster or toe
Old 03-15-2018, 09:41 AM
Member
Bodyboarder1981's Avatar
Crack on ..... shouldn’t have any issues as long as they are torqued up correct
Old 03-16-2018, 04:27 AM
S2Bray's Avatar
Cheers fellas.
Do we think standard torque as per wheel nuts?
Old 03-16-2018, 07:07 AM
Member
Originally Posted by S2Bray
Cheers fellas.
i went a bit more on the spacers .... once fitted though , after 50-100 miles whip the wheels off and torque them correctly again
Old 03-19-2018, 01:01 PM
R23USS's Avatar
I am also interested in spacers for exactly the same reason, my question would be.. What size spacer can we safely run on OEM wheels front/rear without having issues with the fenders?
Many thanks to someone who is more knowledgable than me..
Old 03-20-2018, 02:24 AM
Mike RT4's Avatar
That is ride height dependent.... However, here is 15mm spacers and around a 1" drop (NB. The front is running OEM 8½" wheels):
Old 03-20-2018, 04:56 AM
johnckeen's Avatar
i run 15mm tegiwa bolt on's all round OEM 17's with OEM suspension no issues.
Old 03-20-2018, 10:57 AM
R23USS's Avatar
Thanks alot for that Mike RT4!
Have you ever experienced any rubbing on the liners or fenders with this setup?
I'm on the OEM V2 wheels with Tein Springs, roughly the same ride height I would have thought.
Thanks!
Old 03-21-2018, 12:32 AM
Mike RT4's Avatar
Thanks!
Only on big compressions, where the rears touch the tabs. However, on track - never .
Quick Reply: wheel spacers
