Need advice on potential purchase
Old 09-16-2018, 01:26 PM
dougredpath's Avatar
Question Need advice on potential purchase
Hi there,
I've found a decent looking S2K for sale though it's a long trip south from where I am in Scotland. The topside and interior are excellent for the age, however there's definitely some tin worm underneath (photos attached).
Would this put you off, or does it look like surface corrosion that could be sorted with a proper application of POR/Bilt Hamber/Dinitrol? Of note, the last MOT had no advisories, so hopefully stuff like the brake/fuel lines are clear.
Old 09-16-2018, 02:02 PM
richmc's Avatar
You fail to mention how old the car is, that's usually relevant to how much rust there is. Still nothing that a dose of Waxol won't see to.
Old 09-16-2018, 02:11 PM
Chuck S's Avatar
Received 1,134 Likes on 997 Posts
If this is "just surface rust" the owner should spend a Saturday morning and put it back to original condition. As one might expect I'd not walk across the street to see this car let alone make a several hour trip.
-- Chuck
Old 09-16-2018, 02:30 PM
noodels's Avatar
Looks to be a pre face lift,time effort would sort it,& price dependent.
spec > ???
Old 09-16-2018, 11:21 PM
Thanks for the replies. Re age, it's a 2004 face lift model. Mileage approx 89,000 miles.
Old 09-16-2018, 11:39 PM
S2Bray's Avatar
If someone was to put in a weekend to tidy this up - what would be required? Ie what products and what tools?
Old 09-17-2018, 12:02 AM
Santenay's Avatar
If underneath of the car requires work then the geo bolts certainly will. It would have to be a great price for me to buy it. There are well maintained cars about, have you tried the S2000 Facebook site?
Old 09-17-2018, 12:30 AM
Yeah, I've been on the hunt for a while now. There's an immaculate 28k, single owner, 2004 car on the S2000 Facebook classifieds, but having spoken to the owner it sounds like there's bidding war going on for it. I figured a higher mileage project car would be the go so long as the condition, service history etc lined up. The car posted above in this thread is comparatively cheap, hence it caught my interest.
Old 09-17-2018, 12:43 AM
Nottm_S2's Avatar
You could get the underside and cavities treated for c£500, it's no big deal.
If doing yourself you need wire brush stuff, anti rust primer, dinitrol or waxoyl, overalls, ramps, warm & dry space and time
The arches are a worry though, i would ask for photos of the rear arches inside. It's a 14yo car and has clearly been used in winter.
Surface rust on the rear subframe is very common in the UK
Old 09-17-2018, 02:51 AM
Rapscallion's Avatar
Kind of looks like my old car, perhaps a bit better.
watch out for rear break lines. mine needed replacing at a similar age to this one.
also rear arches. all sorts of nastiness could be going on under the plastic trim. I guess if its cheap enough....
Quick Reply: Need advice on potential purchase
