Idle issue (cannot narrow down the cause)
So I have been having idle issues come up again recently where when i depress the clutch pedal while the car is in motion the idle will hover at around 2k rpms and will continue to stay there until completely stopped where it will fall back to normal range. Also the car will rev up and down on cold start ups at times on its own. I have replaced coil packs, spark plugs, Iacv valve, throttle body, map sensor, spark plug seals and did ecu re-learn procedure. What are your guy’s input. The car is MY2000 with 170k miles
Vacuum leak?
I do not know of any other "typical" ones on this car really.
>>>>>>>>>>>>>>>>>>>>>>UNLIT...……………… ..
I suppose LIT or UNLIT, depends on how much you like the car. Or how much pain it has given you.
Soapy water, sprayed from spray bottle maybe less hazardous? Looks for bubbles, associated with vacuum leak.
