GT 100 engine failures
Old 02-17-2019, 04:38 AM
hereford's Avatar
Default GT 100 engine failures
Hi question to the ones who have been affected.
At what sort of mileages have your engines failed prior to being replaced under warranty ?
Thanks
Old 02-17-2019, 06:58 AM
S2000_sam's Avatar
22k. If any fail now you’d be on your own.
Old 02-17-2019, 08:46 AM
Chuck S's Avatar
Received 1,133 Likes on 996 Posts
There's a different engine in the "GT 100?" (Just curious as this appears to be a UK-only model we don't see here in the US.)
-- Chuck
Old 02-17-2019, 09:56 AM
S2000_sam's Avatar
-- Chuck
As mentioned many times before, we only had the F20C engine in the UK/EU. The “GT 100” was a run out special, no technical differences just colour, hard top, Kaiser Silver painted alloys and a few bits of bling, all were numbered. More correctly the topic is asking about engine issues in the latter years of UK cars, it didnt just happen in the GT 100 cars.
Old 02-17-2019, 10:14 AM
UK Moderator
lovegroova's Avatar
See these:
https://www.s2ki.com/forums/uk-irela...ilures-806996/
https://www.s2ki.com/forums/uk-irela...owners-876045/
Old 02-17-2019, 01:05 PM
Chuck S's Avatar
Thanks. Understood this applies to the very late AP1 engines (long after they were discontinued in US and later Japanese cars).
-- Chuck
Old 02-19-2019, 12:29 AM
ValveBounce's Avatar
I replaced the thrust washers on a 2009 reg car (MY2008) after discovering excessive crankshaft end-float on a standard F20C2. Hopefully I’ve saved the engine before the inevitable failure that would’ve ensued. Honda UK weren’t interested at all, so you would definitely be on your own. Here are a couple of threads if you’re interested:
https://www.s2ki.com/forums/uk-irela...lease-1176019/
https://www.s2ki.com/forums/uk-irela...float-1188376/
hereford (02-19-2019)
Old 02-19-2019, 01:17 AM
hereford's Avatar
Default late model engine failures
Thanks very much to everyone who replied. Sadly it looks like it will be too much of a risk. Was interested in the GT100 advertised in the club classifieds section. Shame looks a real beauty and has obviously been very carefully owned.
Old 02-19-2019, 02:11 AM
How many miles has the engine done? Any problem will have started to manifest itself above say 12000. Ultimate failure might not be until 22000 or so.
If everything else is good with the car then it is still worth a look, but get the crankshaft end-float checked using a DTI by someone who knows what they’re looking at. If it’s in the range 0.10-0.25mm then it’s probably good, 0.30-0.45mm then still worth buying for the right money but immediately take the car to Tom at TGM and ask him to change the thrust washers. Five hours labour and an oil fill and you’re good to go - total bill will be less than £500.
Old 02-19-2019, 05:10 AM
Nick Graves's Avatar
Yeah, statistically it ought to be given the all-clear by now.
If it does display end float, the Belleville washers can be replaced up the sump with the crank in situ. I think it was Ray who managed it.
Quick Reply: GT 100 engine failures
