Aem ground issues need help!
I'm about to smash my aem v2 Ems off the wall idk where this starting issue is comming from. But could it be a bad ground on the car in fully tucked in shave with no engine bay grounds
lmk if anyone has any tips. The car will start every cold but if u shut off right after it won't start or car warm wont start .. 734-309-6267 txt me I can show videos on issues
Did you ever get it figured out?
im having the same problem. Car won’t restart because stat sync’d won’t turn on while cranking. My harness is untouched car is stock except for test pipe.
I know it’s not the tune because even on base map it won’t fire. On stock ECU it’s fine. All my sensors work and battery is good.
