Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
[IMG] Tag errors?
Old Sep 12, 2009 | 05:20 PM
modMonkey's Avatar
Default [IMG] Tag errors?
If you try to edit a post that you put pictures on with the [IMG] tag, it gives you an error.
Specifically: "Sorry, dynamic pages in the [IMG] tags are not allowed"
the page in question is http://video.maxrev.net/Evasive/evasive70mm.jpg
It allowed to post it the first time, but will not let me edit a page with the picture in the [IMG] tags
Thanks!
Old Sep 14, 2009 | 08:32 AM
AquilaEagle's Avatar
Administrator
Edited
Administrator
Works fine. Not sure what you are on about
Old Sep 14, 2009 | 09:13 AM
Quikie's Avatar
Thanks!
Make sure when you are using "[img]" tags there is no spacing between the tag and the image url..... that is what will cause it to give you the error message: "Sorry, dynamic pages in the [IMG] tags are not allowed" Hope that helps!
Old Sep 14, 2009 | 09:47 AM
modMonkey's Avatar
I just double checked, no spacing
AquilaEagle: try to edit this post: https://www.s2ki.com/forums/index.php?showtopic=730182
Old Sep 14, 2009 | 10:47 AM
energetic's Avatar
I have noticed this one as well, only with the code [ YOUTUBE ] [ /YOUTUBE ]. Originally you can post it but if you try to edit it, the error as described above pops up. I just remove the [ YOUTUBE ] [ /YOUTUBE ] and then post only the url.
Old Sep 14, 2009 | 12:36 PM
[DT]'s Avatar
I think the parser is picking up the URL tag embedded in the YOUTUBE tag (which is not allowed), but it's generating an error message indicating the IMG is wrong (and it's not).
Probably just some exception handling that's invoking the wrong or a miswritten source value.
Go back, edit that same page, remove the URL tags and I bet it saves
Old Sep 15, 2009 | 06:38 AM
cthree's Avatar
Administrator
The TUBE and YOUTUBE (first is short form) tags enclose only a YouTube URL. There is probably a bug when tagging/detagging the post on edit like URLs being auto-converted to URL tags before the YOUTUBE tags are decoded causing the [YOUTUBE ][URL ]...[/URL ][/YOUTUBE ] tag sequence when it should be just [YOUTUBE ][/YOUTUBE ].
I will investigate and see if I can replicate the problem and fix it.
* The spaces in the tags above are just to prevent the software from seeing them as valid tags so you can see them. Don't include spaces in your [tags] if you want them to work.
Old Sep 15, 2009 | 11:25 AM
modMonkey's Avatar
thanks cthree
hilarious sig btw
jeffdabella
Mar 23, 2014 10:35 AM
batguano
Jan 8, 2010 05:45 AM
Ragingazn
Aug 16, 2005 01:13 PM
BigMeanBull
83
Jun 9, 2004 07:10 PM
