Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
BULKUPLOAD for pictures fails to load
Old Aug 25, 2010 | 07:20 PM
gpwuster's Avatar
Default BULKUPLOAD for pictures fails to load
I get an Internet Explorer has stopped working message and it doesn't come up with a solution.
This happens on my work computer as well as my home computer.
I'm on win7 ie8 256bit
not sure about my work computer.
Please help
Thanks
Old Aug 26, 2010 | 12:14 AM
energetic's Avatar
Have a read below and check also the settings of your browser's pop-up blocker. Do you have Java installed? It is required as well.
https://www.s2ki.com/forums/index.php?showtopic=727047
Old Aug 29, 2010 | 03:40 PM
Heyitsgary's Avatar
Energetic -
I haven't done a bulk upload in a while, but, I recall a size limitation on the entire process. IIRC, it was either 25 or 50 MB, and if you hit it, the process looks like its going to work, then just stops, with out any information or anything but a failed upload.
Not sure if that was ever resolved. I'm sure there's a 2 or 3 year old thread in site info somewhere with more specifics. FOUND: https://www.s2ki.com/forums/index.php?showt...&#entry13543071
To the OP - What happens if you use the bulk upload and just drop 2 files into the window? Does that work for you?
Old Aug 29, 2010 | 04:53 PM
gpwuster's Avatar
Th Java is installed. I had upload pictures before but it's been a while. I tried it again and it was the same. I also make sure I turned off the popup blocker. I don't know if this has something to do with the IE browser.
When I clicked the BULKUPLOAD, a window came up but not like the window below. It's just kind of blank window.
then immediately, another window popped up over the exit window. On the very top it reads "Internet Explorer" the message said " Internet Explorer has stopped working, a problem caused the programe to stop working correctly. Windows will close the program and notify you if a solution is available."
still
S2KIP
Oct 22, 2015 06:14 AM
macr88
Apr 12, 2013 06:37 PM
caneintn
Jul 15, 2005 07:18 PM
MikeandCheryl
32
Jun 7, 2003 10:48 AM
Jaded41
Oct 25, 2001 09:30 AM
