email notification of PM's
I have successfully sent email to that address from both my aol accounts, and my business account. The only mail that is not comming through is from s2ki. I have checked my spam filters and spam box, there are no blocks and there is nothing in the spam area. The problem appears to be from s2ki. the problem appeared only after my membership renewal.
A little help please. I don't know what else to do
thanks
Mitch
thanks
Mitch
Originally Posted by AquilaEagle,Sep 19 2005, 04:27 AM
OK so my mail didn't get through. The email comes from s2ki.com Your ISP is probably seeing it as spam, not any local settings. Whaich ISP is this mail account?
thanks
It wouldn't hurt to send an email to cthree or the site "support" as it says at the top of this page. He may be too busy to scan this forum.
And it may not be a matter of this site "resetting" anything. It may be something you have to do like logging out, deleting cookies and stuff like that.
Reset your account how exactly? Send me an email support @ s2ki.com if you haven't already and I will try to track down the issue. Emails to your account are getting blocked somehow, AOL is maybe blocking them but this is going to require some reseach to figure out why.
There is nothing I can do to your account other than change the email address that will make any bit of difference. There are only four possibilities I can think of:
1. Your email account info is invalid or incorrect and the mail is being rejected by AOL
2. AOL has blocked email from s2ki because it thinks we are spammers (or because they have blacklisted the IP address block we use; we share the block with others)
3. Our mailserver is broken and it's not even try to send it.
4. Operator error
You've checked 1 and 3 has been tested and working so that leaves #2 as the most likely candidate but as of yet I haven't had any other report of problems with other AOL customers it could also be #4.
If you already sent a message to support@s2ki.com did you get a receipt? You should be a response saying we received your email and you might get a response if we feel like sending one.
4. Operator error
I did some research into this issue and it turns out the problem is #2.
A couple of weeks ago they changed some requirements for mail exchange and they are now rejecting email sent from s2ki.com. It's something I can fix but it might take a few days for it to take. I've already tried to get ahold of Rylan to get our IP to make the necessary changes to the DNS records for our IP addresses.
Thanks for being persistent. I wouldn't have put the pieces together unless this was escalated. I don't typically spend 2 hours searching and decoding log files every time someone says they didn't get an email.
Look for a fix soon I hope.
