What is this?
Can it go down the bottom of the screen?
At minimum it needs the formatting fixed. For those with banners and ads enabled it must take a fair bit of scrolling to get to the first post!
Just noticed, the 'Organised' bit is also in the table below (for the sub-forums) Can it be removed from there and the rest of the table resized a bit to gain back 3 lines of screen? As it is the first post is off the bottom of my screen.
The layout is a work in progress. It will improve steadily over the next while. I'm redoing much of the layout to make better use of the screen real estate while also coping with a greater demand for space.
Erik,
Not sure what is the work in progress part vs. the work completed part, but at least for me, on multiple PCs, both at home and work, the roster link for a various group returns a javascript error. The links for the moderators correctly pull up their profiles.
Since you're going to ask it, yes, IE.
Check your browser/firewall privacy settings. If you have popups blocked then it's going to block the window.open() javascript which opens the roster window. Does the "Assistant" link at the top of the page work? It's the exact same code (I copied and pasted) with just a different URL.
Fixed. The link should work now even on IE6. Just another deviation for the specs problem. Considered Firefox? You should. http://www.mozilla.org
