Site Info Open forum for the discussion of the S2K International site and organization. If you like what we're doing, post it here. If you don't, post it here too. Get answers to site related questions.
What is this?
Old Apr 8, 2005 | 01:57 AM
GSi's Avatar
GSi
Default What is this?
Just noticed it the past couple of days...
Old Apr 8, 2005 | 06:24 AM
AquilaEagle's Avatar
Administrator
Its a list of everyone who has that badge allocated, like the old roster in v3, its not quite finished yet I dont think. The formatting might need changing a bit though
Old Apr 8, 2005 | 06:37 AM
GSi's Avatar
GSi
Can it go down the bottom of the screen?
At minimum it needs the formatting fixed. For those with banners and ads enabled it must take a fair bit of scrolling to get to the first post!
Just noticed, the 'Organised' bit is also in the table below (for the sub-forums) Can it be removed from there and the rest of the table resized a bit to gain back 3 lines of screen? As it is the first post is off the bottom of my screen.
Old Apr 8, 2005 | 10:08 AM
cthree's Avatar
Administrator
The layout is a work in progress. It will improve steadily over the next while. I'm redoing much of the layout to make better use of the screen real estate while also coping with a greater demand for space.
Old Apr 8, 2005 | 11:49 AM
Heyitsgary's Avatar
Erik,
Not sure what is the work in progress part vs. the work completed part, but at least for me, on multiple PCs, both at home and work, the roster link for a various group returns a javascript error. The links for the moderators correctly pull up their profiles.
Since you're going to ask it, yes, IE.
Old Apr 8, 2005 | 02:19 PM
cthree's Avatar
Administrator
Check your browser/firewall privacy settings. If you have popups blocked then it's going to block the window.open() javascript which opens the roster window. Does the "Assistant" link at the top of the page work? It's the exact same code (I copied and pasted) with just a different URL.
Old Apr 8, 2005 | 02:31 PM
Heyitsgary's Avatar
The assistant works flawlessly!
Old Apr 9, 2005 | 06:07 AM
cthree's Avatar
Administrator
Fixed. The link should work now even on IE6. Just another deviation for the specs problem. Considered Firefox? You should. http://www.mozilla.org
Legal Bill
Aug 27, 2004 11:19 AM
1Y2KS2K
Nov 20, 2000 10:46 AM
