Mark this thread as Sold
100% Complete Inline Pro Turbo kit
Old Jan 12, 2011 | 09:36 PM
TRBOKEV's Avatar
Default 100% Complete Inline Pro Turbo kit
First Name: Kevin
Price: asking 5000 for EVERYTHING!
Contact: Please contact me via PM
This is EVERYTHING you are going to need in order to hit street!!!!!
Inline Pro Street Kit not “Tuner” Kit
Here are a few pictures, I will try my best to get some more soon.
These are the costs of parts:
Turbo kit: 4000
Ball bearing upgrade 500
Coating on manifold: 200
Turbo manifold match ported: 100
Downpipe: 1200
AEM 1052U: 1200
Fuel pump: 100
Injectors: 475
Turbo blanket kit: 150
Oil pan/tapped for return: 150
AEM boost solenoid, 3.5 bar map sensor, oil press sensor and custom harness: 225
Vacuum lines, upgraded T-bolts, ARP studs for top exhaust bolts, custom overflow bracket etc: 150
Base map: (I paid 450 for my tune and put many hours into further tuning it after)
Total I spent: 8900
Inline Pro Cast Bottom Mount Manifold
o HPC Coated
o Gasket matched & port casting cleaned Up
o ARP Exhaust manifold studs (3) for top studs
Intercooler Piping
o Polished
o Premium Stainless T-Bolt Clamps
Precision Ball Bearing 5965 w/ B cover
o About 3000 miles of service
o Water Cooler Center Section
o Oil Drain Line
o Turbo Oil Drain Adapter
o Oil Pan Pretapped included!
o Turbo Oil Supply Line, Fittings & restrictor
38MM Turbosmart Ultragate - Wastegate
o Stainless Steel dump tube wrapped in DEI Titanium heat wrap
3” Custom Made Tig Welded Stainless Downpipe (1250 dollar
item custom made by SP Engineering in the City of Industry)
o 3” Sound Performance Boost Actuated Cutout
o 4” Stainless Flex Joint
o Bolts Up To Factory 3” House Flange to meet up to factory exhaust or
ANY catback S2000 exhaust!
o Secondary 02 Bung
• Precision 600HP Intercooler w/ Custom Brackets
• Inline Pro Oil Filter Relocation Kit
• AEM oil pressure sensor
• AEM boost solenoid
• Custom harness for boost solenoid and oil sensor (plug and play)
• AEM Dry Flow Filter
• Custom Turbo to Filter Standoff
• Inline Pro Blow Off Valve
• DEI Turbo Blanket
• Custom coolant Reservoir Bracket for overflow relocation
• Inline Pro Instructions
• All Required Hardware to Install
• Vacuum Hoses
• ISP Secondary Air Injection Block Off Plate
• NGK BKR8EIX Spark Plugs
• *NIB* Walbro 255LPH Fuel Pump
AEM EMS 1052U
o *NIB* Wideband O2 Sensor plus good current sensor being used
o AEM 3.5 Bar Map Sensor & Pigtail
o AEM Boost Solenoid & Fittings
o High speed RS232 to USB cable with software
Injector Dynamics 1000cc Injectors
o PNP Injector Pigtails
o Spacers & Extra injector and intake O-rings
Free Base Tune
Here are the additional pictures of the parts off the car. (taken this morning)
Old Jan 13, 2011 | 07:17 AM
TRBOKEV's Avatar
BUMP!
Old Jan 13, 2011 | 06:54 PM
Randizzle88's Avatar
Very nice :-)
Old Jan 14, 2011 | 08:38 AM
03supers2k's Avatar
BUMP for Kevin
Old Jan 14, 2011 | 10:31 PM
TRBOKEV's Avatar
Originally Posted by 03supers2k,Jan 14 2011, 09:38 AM
BUMP for Kevin
Thanks Lee.
Old Jan 17, 2011 | 11:27 AM
TRBOKEV's Avatar
Bump for 27 new pictures!
Old Jan 17, 2011 | 10:07 PM
TRBOKEV's Avatar
Old Jan 18, 2011 | 03:59 PM
TRBOKEV's Avatar
TTT
Old Jan 19, 2011 | 09:08 AM
TRBOKEV's Avatar
Old Jan 19, 2011 | 06:52 PM
TRBOKEV's Avatar
Somebody has to want boost!!
