Mark this thread as Unsold
Delete
Old Jul 10, 2008 | 11:10 PM
J.nguyen's Avatar
Red face Delete
Delete
Old Jul 10, 2008 | 11:41 PM
JDM AP1's Avatar
after you replaced it did you even bleed it out to get all the air out?
Old Jul 10, 2008 | 11:44 PM
reds2's Avatar
There is a nipple on the thermostat. Did you get that lined up?
Old Jul 10, 2008 | 11:52 PM
J.nguyen's Avatar
i ddnt touch the T-stat because radiator install ddnt require me to do that,
yeah i blead the coolant when i installed it, even if i ddnt bleed it, air bubbles wouldnt force my car to be overheating this much and not blowing hot air in interior
Old Jul 11, 2008 | 07:00 AM
Sinji's Avatar
its sounds like the system is not properly bled due to the air not blowing hot and the fan not turning on.
Old Jul 11, 2008 | 12:40 PM
modMonkey's Avatar
Your problem is def. Air bubbles. I had the same symptoms. Like sinji said, if the heater doesnt blow hot, its air bubbles. Make sure you open both bleeder valves. and re-purge.
Old Jul 11, 2008 | 01:26 PM
chrisesteban's Avatar
bleed the system. i had the same problem.
Old Jul 11, 2008 | 05:43 PM
NFRAP1's Avatar
Both?
I thought there was only the one? (in between valve cover and im)
Just asking, becasue I just installed a Mishimoto radiator last week.
Old Jul 11, 2008 | 08:59 PM
wisdom's Avatar
Theres another one right next to the fire wall. A black rubber piece with a metal clamp.
Old Jul 12, 2008 | 01:55 AM
modMonkey's Avatar
Originally Posted by NFRAP1,Jul 11 2008, 05:43 PM
Both?
Yup there is two. As wisdom mentioned, there is one by the firewall too. Should be pretty easy to spot.
S2K_Vtec
Jul 9, 2015 11:49 AM
Margil
May 13, 2014 01:51 AM
Mr Ak
Nov 3, 2012 09:20 AM
kutsujula
Feb 12, 2008 04:18 AM
