delete idle air control valve
Old May 11, 2014 | 09:22 PM
Margil's Avatar
Default delete idle air control valve
I remove the AC and air pump last year. Now I want to delete idle air control valve. Has anyone done this? I know you can just bypass the small coolant lines going to the air control valve. I want to clean up the engine.
Old May 12, 2014 | 06:16 AM
vtec9's Avatar
You want to remove the coolant lines, or delete the entire IAC? The former can be done if you live/drive in warm weather since the coolant lines are to prevent icing.. but when removing the entire IAC I question how the heck you are going to control air flow when idle.
Old May 12, 2014 | 07:23 PM
Mike21's Avatar
idle control valve is what maintains idle. you dont want to delete that...
Old May 12, 2014 | 08:14 PM
Slows2k's Avatar
Buy a 2006 or later car. No IAC.
Old May 12, 2014 | 08:40 PM
realblag's Avatar
Old May 13, 2014 | 01:51 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
This is your only option.
james0933
Aug 26, 2019 08:48 AM
maxl
May 5, 2014 08:43 AM
nissfam
Sep 24, 2012 03:37 PM
J.nguyen
Socal Swap Meet
Jul 12, 2008 01:55 AM
kutsujula
Feb 12, 2008 04:18 AM
