South Florida Owners from South Florida
Maintenance Required light?
Old Sep 12, 2004 | 10:03 AM
js2k24's Avatar
Unhappy Maintenance Required light?
maintenance required light came on, has this happened to anyone? I have 39,000 on my car. Yesterday the battery acted up a little bit, when I put gas if you leave the radio on while the car off is that really going to kill the battery? 5 mins tops while filling up the gas tank.
Old Sep 12, 2004 | 10:08 AM
JerseyGirl's Avatar
Do you know if the maintenance required light was reset the last time an oil change was done? If it wasn't, it may be showing up now, just indicating that you're coming up to some sort of procedure that should be done (based on mileage).
Old Sep 12, 2004 | 10:09 AM
DaWorm's Avatar
The maint light comes on every so often. Its simple a reminder to change the oils and take it in for servicing..
Old Sep 12, 2004 | 10:32 AM
js2k24's Avatar
oh ok well I am taking it in on Tuesday so hopefully it won't be nothing. I am also going to have them check that spindle nut noise.
Old Sep 12, 2004 | 02:23 PM
MacGyver's Avatar
The MIL light is merely mileage based, not true maintenance. Some dealerships will actually charge you like $50 to reset it, so watch out.
Old Sep 12, 2004 | 03:45 PM
Spa02S2K's Avatar
Look in your Owners Manual, under "Maintenance Required Indicator"
To reset the maintenance required indicator, turn the ignition switch to the LOCK position, then press and hold the trip meter reset button while you turn the iginition switch ON. Continute holding the button until the indicator light goes out....
Tada problem SOLVED!
Old Sep 13, 2004 | 12:02 PM
js2k24's Avatar
sounds good spa thanks for the tip.... one more thing though, has anyone had problems with their stock battery? Or when did you change this battery? at what mileage?
Old Sep 13, 2004 | 01:00 PM
MacGyver's Avatar
Nearly 75k miles, completely drained it by accident twice, still the same battery.
Old Sep 13, 2004 | 01:27 PM
js2k24's Avatar
Thumbs up
oh ok thanx for the advice, see mine if I leave the radio on for 5 mins or so it will cause the car to hold the push start button for a little bit longer like if the battery has been drained a bit. do you experience the same? I almost took it for normal for a while because the battery is the size of a walnut...lol....what do you guys think? 10 mins of radio and the battery is totally dead???
Old Sep 15, 2004 | 02:09 AM
S2KSuzuka's Avatar
my battery lasted almost 2 years, was still under warranty and Honda replaced it.
Mitch
