South Florida Owners from South Florida
My S is starting to buck when hot
Old Jul 18, 2007 | 08:10 AM
MIAMI S-2000's Avatar
Default My S is starting to buck when hot
I 'm new to this car, so I've reading about the lack of torque from a stand still and so on, so I've been reving up a little more on take off, but now when it is coasting at low speed in 2nd gear or 1st in stop and go traffic, it bucks. Do these AP's suffer from heat lock or is it something else? Help!!
Old Jul 18, 2007 | 08:45 AM
DSMRacer's Avatar
LOL this is normal. Trust me, if freaked me out to when I first got the car, I thought something was wrong with it.
This is an easy fix. You can either gut your stock air box and/or purchase a snorkel which will eliminate the bucking. I've gutted my air box and almost never happens, unless I've been sitting in traffic for a very long time.
But, I suggest gutting the airbox and going from there.
edit: I just realized you have a CAI, is it a shortram??
Old Jul 18, 2007 | 08:51 AM
notamaster's Avatar
Do have the full cold air intake or the short version. It's heat soak in the intake system. Thats normal
Old Jul 18, 2007 | 09:25 AM
It is an Injen but is missing the piece that goes under the front bumper, so I have it facing the original air intake opening between the hood and the radiator, but it isn't insulated or cold air boxed.
Old Jul 18, 2007 | 09:34 AM
notamaster's Avatar
Thats heat soak. See if you could get the other section or a cooling plate may help.
Old Jul 18, 2007 | 09:50 AM
Pardon my ignorance, but "What is a cooling plate"? Also I don't like the idea of having the filter so close to the ground, with all the floods we get in this area!
Old Jul 18, 2007 | 10:11 AM
notamaster's Avatar
Do a sheach for a AUT cooling plate. They have them in the group buy section on the forum. That should help direct some cold air to your filter.
Old Jul 18, 2007 | 10:47 AM
M.A.R.C.'s Avatar
dude... CAI = cold air intake
short ram refers to an intake that sits under the hood and therefore has shorter piping
anyway... try the snorkel. it has worked well for me in conjunction with dousing my MAP sensor with MAF cleaner
Old Jul 18, 2007 | 11:08 AM
DRE.'s Avatar
Originally Posted by M.A.R.C.,Jul 18 2007, 01:47 PM
MAF cleaner
Whats that? And what does it do?
Andres
Old Jul 18, 2007 | 01:18 PM
M.A.R.C.'s Avatar
MAF cleaner is just what the name says it's a cleaning spray for MAF (Mass Air Flow) sensors. It's similar to carb cleaner except it's supposed to be sensor safe. especially on older cars there can be a lot of carbon buildup and such in or around the maf (or map)
http://www.amazon.com/CRC-Mass-Flow-Sensor...r/dp/B000EGH57G
