South Florida Owners from South Florida
Question abouts Rims and Sizes
Old Jun 22, 2008 | 09:13 AM
HighwayStar's Avatar
Thumbs up Question abouts Rims and Sizes
Im thinking about getting a set of rims.
I know the Stock set up is 17x7.0 / 17x8.5 but i was thinking of going 17x7.5 or 8 / 17x9.
Would this set up be a good idea?
would the car grip and handle Better?
What about matching size all around is that better?
Also what about tire sizes what would be the best set up for this?
And Offset i have no idea what that i would need.
Old Jun 22, 2008 | 09:39 AM
zdave87's Avatar
Member
I think it would depend on what you want to do with the car.
Is it for show/autocross/track days etc? Each option is totally different.
Old Jun 22, 2008 | 09:49 AM
No for show. I guess track like the to get the most handling out of the car. I want to take turns like a mad man lol
Old Jun 22, 2008 | 10:02 AM
zdave87's Avatar
Member
I don't think a larger tire will get you *that* much more cornering speed-if anything-you'd want a gripperer tire.
Alex (fyrestrike) & Rene (Prospect S) will have a better answer than me.
Old Jun 24, 2008 | 03:54 AM
Fyrestrike's Avatar
The best way to do it is to pick a wheel style that you like, then figure out what offset/width options they have make that fit the S2000. For handling I'd go no bigger than a 17", tires are cheaper too.
Old Jun 24, 2008 | 05:42 AM
AP-DUECE's Avatar
i have 17x8 and 17x9 and they are perfect!
Grip
Old Jun 25, 2008 | 06:18 AM
jimreaper's Avatar
Grip
WHat's your offset and tire size on front and back? Thanks
Old Jun 25, 2008 | 06:29 AM
I would like to know too
Old Jun 25, 2008 | 07:57 AM
X4DLuvOfSpeedX's Avatar
+45 offset seems to be the limit for a 9" rim with at the rear without causing too many headaches. For street I think it's the best look. Deep enough for a decent lip but still sits flush with the fender. You might have to roll your fenders a little if you're lowered. Run it with a 245 tire, or a 255 if you're willing to go for a little more negative camber. With higher offsets (lower number) you'll need to run very aggressive camber, especially if slammed. Some people manage to fit +35 9" rims and run them without problems.
Edit:
Here are some RPF1 in 17x8" front, 17x9" rear, both in +45 offsets. Tires are 215 front & 255 rear:
Old Jun 25, 2008 | 09:15 PM
jeffbrig's Avatar
To give you another data point on wheel fitment, I have the 17" Volk ce28n setup.
front:17x7.5" +50 offset w/225/45 tire
rear:17x9" +63 offset w/255/40 tire
The high rear offset helps to tuck the wheels inside the fender.
dam2
Sep 25, 2012 07:01 AM
moto2K1
Feb 4, 2006 05:11 AM
viper11blue
May 27, 2004 06:40 AM
all-trick'd-out
Mar 28, 2004 05:24 PM
tripod
May 9, 2001 03:54 PM
