Need Help!
"A common misconception is that a 12-point socket is more likely to round off the corners of a nut or bolt than a 6-point socket. In fact, since the torque is applied at the corners of the fastener, the two sockets have the same number of contact points, apply the same amount of torque, and one is no more likely to round off the corners than another. Although extensive industry testing documents this fact[citation needed], the myth persists."
Number of Points (shape)
Originally Posted by FluKy15' timestamp='1337535574' post='21714284
Make sure you use a 6 point boxed end wrench if you can find that, NOT a 12 point. I repeat on that, NOT a 12 point anything.
My Dad told me about this, he has years of experience wrenching (20 years) and I found the same results. When I used the 12 point with lots of torque I tend to round the bolts/nuts too.
you round off that bolt/nut with a socket because it doesn't sit flat on it bc the cat pipe buldge is in the way. Closed end socket is really the only way to go with that. Put it on and give it a good smack.
If this does not work, heat the bitch up red hot, shock it with some water in a spray bottle, and then smack it again.
If problem persists, repeat above but get it hotter this time
Red_Ohio_Rocket
Jan 27, 2003 07:55 AM
