Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Spark plug change/check
Old Nov 5, 2009 | 10:45 AM
kwasley's Avatar
oem is NGK pfr7g-11s's or DENSO
Old Nov 5, 2009 | 05:53 PM
sketch's Avatar
[QUOTE=kwasley,Nov 2 2009, 12:05 PM] damn, how many K's are you at now
Old Nov 5, 2009 | 06:18 PM
starchland's Avatar
id hope so, they do seem to take boost fairly well provided a good tune and not crazy psi or anything. the only thing that concerns me is the oil bolts and stories of oil consumption.
Old Nov 5, 2009 | 07:23 PM
sketch's Avatar
Most if not all VTEC motors consume oil, just be thankful its not an H22 in our cars.
Old Nov 10, 2009 | 11:30 AM
zeroptzero's Avatar
Originally Posted by kwasley,Nov 4 2009, 05:38 PM
are you running the stock gap on those iridiums of .03?
are you FI?
I was considering those but adjusting the gap on iridiums can be tricky and im not FI.
im going to stick with the ngk pfr7g-11s's
no my engine is totally stock. I run the stock gaps on them at .043". Adjusting gaps on Iridiums is perfectly fine, you do have to be careful about it though, and not be overly rough when checking the gap with the wire gauge. The NGK centre electrodes are pretty strong, not as thin as the Densos. I've adjusted them dozens of times on different vehicles and never had any break on me, even on turbo apps.
I like the Iridium NGK design as it has the v-trimmed ground electrode, and the Iridiums require less voltage to fire than other plugs, which should equate to a better spark IMO. I'm set on replacing them every couple years too.
s2kbsd
May 15, 2015 12:04 PM
Paperboy7777
Jan 9, 2012 09:23 AM
speakeasy2009
Aug 28, 2011 06:17 PM
boy blue11
Oct 22, 2010 08:00 PM
SpEeDxXxRaCeR
Nov 4, 2005 05:19 PM
