Sponsor S2000 Electronics and S2000 Audio Deals Sponsor deals on S2000 Electronics and S2000 Audio products including entertainment and navigation systems
NEW Innovate Motorsports Dual Function Gauges at MVP Motorsports
Old May 9, 2012 | 09:05 AM
Chops@MVP's Avatar
Former Sponsor
Default NEW Innovate Motorsports Dual Function Gauges at MVP Motorsports
Innovate Motorsports has just introduced their newest line of gauges. A solution for those who need quick access to vital engine information but don't want tons of gauges on their dash! Introducing the Innovate MTX-D Dual Function Gauge Line for 2012!!!
MTX-D: Vacuum / Boost & Shift Light
DISPLAY RANGE
  • Boost: -29 inHG to 43.5 PSI (-1 to 3 BAR)
  • Shift: Up to 20460 RPM
KEY FEATURES
  • Display as either inHG/PSI or BAR (Digital Display)
  • Over Boost Warning (Digital Display)
  • Progressive Shift Light or Single Stage Shift Light (outer LEDs)
MTX-D: Oil Pressure & Temperature
DISPLAY RANGE
  • Pressure: 0-100 PSI (7 BAR)
  • Temp: 120-280 °F (49-138 °C)
KEY FEATURES
  • Pressure
    • Display in either PSI or BAR (Digital Display)
    • Program Low Oil Pressure Warning (Digital Display)
  • Temperature
    • Change exterior LED as a fill bar or light a single indicating LED
    • Program exterior LED ranges vs. Color
    • Program unit of measure as °F or °C
    • Program Oil Temperature Warning (outer LED
MTX-D: Water Temperature & Battery Voltage
DISPLAY RANGE
  • Water Temp: 120-280 °F (49-138 °C)
  • Battery V: Volts 6 - 25 VDC
KEY FEATURES
  • Water Temperature
    • Display in either °F or °C
    • Water Temp Warning (Digital Display)
  • Battery Voltage
    • Program exterior LED ranges vs Color
    • Program Voltage Warning (outer LEDs)
MTX-D: Exhaust Gas Temperature (EGT)
EGT gauge is "SINGLE FUNCTION"
DISPLAY RANGE
  • Temp: 32 - 1999 °F (0-1093 °C)
KEY FEATURES
  • Change from EGT to CHT range. CHT range allows greater resolution
  • Program EGT Warning.
PM OR POST UP FOR S2KI SPECIAL PRICING!!
Regards,
Robert
Old May 12, 2012 | 09:13 AM
Excalibur's Avatar
You can get them all with black faces correct?
Old May 14, 2012 | 03:01 PM
Chops@MVP's Avatar
Former Sponsor
Your purchase includes both White and Black faces which are interchangable.
Regards,
Robert
Old Sep 26, 2012 | 05:57 PM
Buntinboy9's Avatar
How easy is the install for the oil pressure and temperature gauge and does it come with everything needed to install and adapt it to our cars?
Old Oct 1, 2012 | 09:06 AM
Chops@MVP's Avatar
Former Sponsor
They are universal gauges and will work with any vehicle. It comes with all wiring/sensors but you will steel need to modify your setup to accept the additional sensors.
Regards,
Robert
Old Oct 27, 2012 | 11:20 AM
theprophet36's Avatar
Can you get the MTX-L, p/n 3844? If so, how much shipped to 06082? Thanks
Old Oct 31, 2012 | 03:48 PM
Chops@MVP's Avatar
Former Sponsor
PM sent!
Regards,
Robert
Old Nov 1, 2012 | 09:24 AM
Kyushin's Avatar
Banned
Price for oil pressure and temp gage
Old Mar 29, 2015 | 03:45 AM
skinsfn36's Avatar
Any reviews of these being used/installed?
s2konroids
Apr 12, 2010 05:28 PM
s2konroids
Apr 12, 2010 01:13 AM
afwfjustin
Apr 4, 2007 07:07 AM
mattunh
Aug 19, 2005 01:16 PM
