*KamiSpeed* Fortune Auto Coilovers 500 & 510 Series
FORTUNE AUTO 500 SERIES COILOVERS© (Occasional Track Use) -$1,199
500 series coilovers incorporate a DIGRESSIVE* piston, 24-step damping, custom rates & a five year warranty
500 Series coilovers are CUSTOM built to order.
DIGRESSIVE* All Fortune Auto shock absorbers use Digressive piston technology. This technology allows for stiff low speed rebound force which helps give better control of driver inputs such as roll, dive and squat. However, at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
*Dyno tested
*Mono-Tube damper with high pressure nitrogen
*24-step rebound adjustable dampers
*Spherical Bearings
*FA synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
*T6 6061 Forged & Anodized aluminum mounts and camber plates
*Bright Dip Anodized
*Height adjustment independent of pre-load
*Digressive piston technology
*5 year Manufacturer's Warranty (1 year on piston)
*Swift springs upgrade available
*Rebuild-able in the USA
*Revalve-able in the USA
*Modularity - Upgradeable to 2-Way Canister*
FORTUNE AUTO 510 SERIES COILOVERS© -$1,699
510 series coilovers incorporate a "ULTRA" DIGRESSIVE* piston, 24-way damping, custom rates & a one year warranty
510 Series coilovers are CUSTOM built to order.
Incorporates all the great features of our 500 series coilovers. Furthermore it includes our new "Ultra" Double Digressive Pistons.
Featuring our new "Ultra" Double Digressive Piston (UDDP) with revised shim stacks, this "Ultra" Digressive piston allows for massive amounts of low speed rebound force that helps with driver inputs such as dive, pitch and roll. Furthermore, the rebound force greatly tapers off to provide the driver with "blow off" This helps with large impacts on track helping the vehicle stay settled after hitting curbing at high speeds. After countless hours on the shock dyno and testing on the track, we are proud to offer these high performance coilovers that rival many high end European shocks that cost several thousand dollars more. Due to the ultra digressive nature of this shock absorber, this product is recommended for track use only.
*Assembled in the USA
*Dyno tested
*Dyno graph supplied with all 4 shocks
*Asssembly certificate (documenting build & QC)
*Radial bearing mounts standard (on MacPherson)
*Spherical Bearings
*Amsoil synthetic shock oil (the ultimate in shock oil technology)
*6061 Forged & Anodized aluminum mounts and camber plates
*"Ultra" Digressive piston
*Compliant track suspension solution
*Rebuild-able
*Revalve-able
Optional Upgrades:
Rear Adjustment Extender ($45)- Easier rear damper adjustment.
Swift Springs ~ $320 w/ purchase of coilover. *This option gets you Swift Thrust Sheets for FREE*
Swift Assist Springs ~ $300 ( Increases comfort and prevents loss of traction during rebound. ) w/ purchase of coilover.
Swift Thrust Sheets ~ *FREE with Swift Sping Upgrade ( Allows the spring to smoothly rotate around the perch. Decreases noise level greatly. ) w/ purchase of coilover. *Since the S2000 cannot utilize the Radial Bearings offered by Fortune Auto*
*Dyno tested
*Spherical Bearings
*Dyno tested
*Spherical Bearings
*Rebuild-able
*Revalve-able
Optional Upgrades:
