Sakebomb Garage Christmas - BLOWOUT
Sakebomb Garage went through one of the biggest moves to a new location! This gives us more space and a greater ability to serve you, our family. That being said, to allow for all our new products arriving this coming 2018 year! We need to blow out our shipping department with some awesome prices this one time only!
WILWOOD TRACK-DAY BRAKE SYSTEM (S2000)
$1195!
Wilwood Track-Day Brake System (S2000) - SakeBomb Garage LLC
We are proud to introduce our new Wilwood Track-Day Brake System. Building on the success of our AP Competition Brake System, we produced this brake kit, with the intention of bringing race-inspired engineering to the broader motorsports market. Utilizing many of the specifications of our AP kit, we have designed what is in essence, a light-competition brake system, employing high-end track & street components. The result is a system which provides incredible performance for cost, accessible to the broader driving enthusiast market, which can be easily upgraded to race-performance components if you choose.
AP COMPETITION BRAKE SYSTEM (S2000)
$2595!
AP Competition Brake System (S2000) - SakeBomb Garage LLC
Our goal for this braking system was to shatter the performance limitations offered by most of the current braking solutions on the market. We chose to engineer our brake setup around AP racing components based on their continued success in top tier motorsports, such as the American Le Mans series, Grand-Am, NASCAR Sprint Cup, NASCAR Nationwide Series, and Formula 1.
SBG COMPETITION REAR BRAKE SYSTEM (S2000, REAR RX8 CALIPER RETROFIT KIT)
$995!
SBG Competition Rear Brake System (S2000, Rear RX8 Caliper Retrofit kit) - SakeBomb Garage LLC
Our goal for this rear braking system was to provide a high-torque rear brake solution for the Honda S2000 which retains the stock e-brake. This rear brake system was developed to be used in conjunction with our AP Competition Front Brake Kit for the S2000. While our Competition Front Brake Kit performs exceptionally well, the stock rears (or '99 spec for that matter) left some additional braking potential on the table. Our rear brake kit utilizes the stock caliper with a billet 6061 aluminum relocation bracket to increase and optomize rear brake torque by allowing the use of our custom 330mm two piece rotor (vs 294mm stock rotor). Our rotor is designed with a hard anodized aircraft-grade billet 2024 aluminum hat to withstand extreme temperatures, and is mated to our 330mm directional curved vane discs with aero-space hardware.
FPSPÖRT ÖHLINS DFV (S2000)
$2395!
FPSpört Öhlins DFV (S2000) - SakeBomb Garage LLC
Since its introduction, the Öhlins DFV line has revolutionized coilovers, and as a result, no longer are customers forced to choose between performance and ride quality. The Öhlins DFV valving design made it possible to have a truly track worthy damper that was also not only livable, but actually comfortable on the street, without sacrifice to performance driving. As suspension engineers, the one thing that always frustrated us was being forced into the mold of a standard off the shelf suspension settings. The vast majority of our Ohlins customers ultimately decide to purchase new springs for their DFVs, and we designed this SBG Exclusive suspension kit around the most popular settings amongst our customers, and included optimized valving to accept a wide range of performance street and track worthy spring rates. We include stronger and lighter aluminum lower mounting forks and custom top hats with teflon lines spherical bearings. The optimized valving curves offer much improved ride quality over the standard DFV kit, and elevated performance out of the box. For roughly the cost of a DFV kit and replacement springs, this kit is a no-brainer for any S2000 driver!
ÖHLINS DFV Add on lowering forks for $75 (S2000)
$2075!
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world.
The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises is over! We run these on our own cars, and yes, they are that good.
FPSPEC OHLINS DFV LOW-PROFILE MOUNTING FORK (S2000)
$170!
FPSpec Ohlins DFV Low-Profile Mounting Fork (S2000) - SakeBomb Garage LLC
We sell a lot of Öhlins DFV and although we hear almost nothing but great things about them the single recurring comment is that the rear damper doesn't allow the car to be lowered to the ideal height. Regardless of if you are running high spring rates for the track, enough preload to achieve ultimate performance on the standard springs or even trying to live life hellaflush, the standard lower mount design leaves a lot to be desired. We recommend a high amount of rear pre-load with near standard spring rates (8-10KG) when setting up the conventional DFV suspension due to the limited available stroke. 10-30mm of spring pre-load is needed to obtain an optimal balance of compression and rebound and stay off the bump stops for best ride quality. This does come at a cost however, as it will limit the amount of ride height adjustment the can be achieved. As pre-load increases, the damper length must decrease to keep the car at the same ride height. Unfortunately the standard lower mount does not allow the car to be lowered as much as many people would like, especially with the correct amount of preload. This is where our mounts come in!
FPSPËC ÖHLINS DFV REMOTE DAMPER ADJUSTERS
$100!
FPSpec Ohlins DFV Remote Adjusters!
Do you have Ohlins? Do you have an interior? Perfect, we've solved your damper adjustment problem once and for all. For years we've been frustrated with choosing between being able to adjust our suspension and have an OEM interior fitted. To solve this dilemma we've engineered a seamless remote adjuster solution which allows panel a remote extension cable and knob. Common sense? We thought so.
SBG COMPETITION OIL COOLING SYSTEM (S2000)
Starting at $445 base price!
SBG Competition Oil Cooling System (S2000) - SakeBomb Garage LLC
Features:
$1195!
$2595!
$995!
$2395!
$2075!
$170!
$100!
Features:
- Maximize cooling efficiency to protect your motor, and eliminate overheating concerns by taking significant load off of the water cooling system.
- Direct bolt-on, with no fabrication, modification, or custom work involved
- OEM look and fit
- High-quality components/brackets, yet still more affordable than the competition
- Two cooler sizes: Different oil-cooler capacities to fit your car's cooling requirements, and your budget.
- Coolers can be swapped out at any time to upgrade capacity, and coolers will work with any aftermarket front bumper
- Over-engineered: Pressure and temperature ratings for ALL of our lines and fittings vastly exceed the maximum pressure and temperature ever generated by the oiling system, to ensure durability and longevity.
- OEM look and fit
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
Wasn't really planning on buying anything, but maybe I should now! The price for the FPSPEC OHLINS DFV LOW-PROFILE MOUNTING FORK (S2000) is for the pair, right?
SakeBomb Garage (12-24-2017)
Yes! This is for a pair!
__________________
Hey! for standard DFV's we recommend 18mm unless you're 10kg rear springs. In which case you can get away with 9mm
__________________
egar2009 (12-31-2017)
Sale ends the 1st of the year, last chance to get prices this low.
__________________
