Tampa Gulf coast and surrounding areas...there be pirates here!!
Grinding noise
Old Feb 13, 2010 | 04:10 AM
Brando's Avatar
Default Grinding noise
Hi everyone,
I know a lot of you are more technical than I am. I'm having a grinding noise from my front driver's side wheel. It started happening on left turns, but now it primarily happens on right turns even without braking. I have 47,000 on my '05.
My first thought is brake pads, but I would think that would make noise all the time, not just on turns. From searching other forums on here it sounds like it may be a wheel bearing too. I pulled the wheel and took a look, and I think the inner brake pad is low. I'm going to change those this weekend, but my question is:
Does this sound like brake pads or a wheel bearing, or should I be checking something else?
Thanks,
Greg
Old Feb 13, 2010 | 04:31 AM
l0v35tik's Avatar
It happened to me. Got new brakes and the noise went away...
Mine was coming from the right front wheel. Every time I made a turn
I would hear the grinding noise. Eventually it would do it all the time, not just on turns.
~Cristian
Old Feb 13, 2010 | 04:32 AM
l0v35tik's Avatar
around the same mileage, too...
Old Feb 13, 2010 | 05:22 AM
JohnsS2000's Avatar
Make sure that your rotors are not rutted from the rivots in the pads. When ya get to low that can happen. Check both sides of the rotor
Old Feb 13, 2010 | 08:41 PM
Brando's Avatar
Thanks guys. I figured that would be the case, but I wanted to make sure that I wasn't overlooking anything. I would hate to change parts that don't fix the problem.
Old Feb 15, 2010 | 12:31 PM
2big4aS2000's Avatar
turn your rotors and flush and use new brake fluid... could have a sticking caliper...
j12
Jul 28, 2010 02:04 PM
jimmhatch
Apr 30, 2009 04:07 PM
boosted_ap1
Apr 18, 2008 05:58 AM
noodle
Jan 23, 2008 10:58 AM
mwy23
Sep 12, 2004 10:39 AM
