Tampa Gulf coast and surrounding areas...there be pirates here!!
need your input on this issue please
Old Jun 4, 2014 | 01:36 PM
js2krazy's Avatar
Default need your input on this issue please
need your input on this plz. On my way to work this morning RPM was fluctuating in the beginning, then when I'm going to a complete stop RPM would drop all the waaay down bellow 500, and all of the sudden it'll STALL. It did that for the entire way to work whether the clutch was pressed or not. check engine never came on ! It was fine on my way back even the Honda Tec. thought It was odd ? Need opinions thnx in advance
BTW i've Remove the map sensor and cleaned the chambers over 2 months ago !?
Old Jun 4, 2014 | 01:48 PM
JUSTINTHECOASTIE's Avatar
Originally Posted by js2krazy
need ur input on this plz. On my way to work this morning RPM was fluctuating in the beginning, then when I'm going to a complete stop RPM would drop all the waaay down bellow 500, and all of the sudden it'll STALL. It did that for the entire way to work whether the clutch was pressed or not. check engine never came on ! It was fine on my way back even the Honda Tec. thought It was odd ? Need opinions thnx in advance, hopefully the huge font made it easy to read
BTW i've Remove the map sensor and clean the channel over 2 months ago !?
1.) change your letter size from a 5 to normal
2.) It could be a couple of things
3.) Contact LHT Performance so they can explain to you what is possibly going on with your after to make an appointment to see them 727 344 1800
4.) Hope everything works out
Old Jun 4, 2014 | 02:39 PM
js2krazy's Avatar
thanks justin consider #1 is done LHT is on my mind i just will have to wait until the weekend
Old Jun 4, 2014 | 06:24 PM
robhoy's Avatar
You might also try the Under the Hood forum here -- https://www.s2ki.com/s2000/forum/22-...nder-the-hood/.
Old Jun 4, 2014 | 06:41 PM
Metcalfe's Avatar
Swing by the shop Saturday...pretty sure I know what it is.
Old Jun 4, 2014 | 06:54 PM
js2krazy's Avatar
will give you a call before i stop by, thank you sir
Old Jun 4, 2014 | 07:07 PM
Gbcrebel13's Avatar
May want to check your IAC valve. My S was doing the samething when I first got her, 20 minute job cleaning the IAC and have never had the problem again.
Old Jun 5, 2014 | 12:31 AM
Blacknot's Avatar
Clean out the TB and remove the IAC and soak with WD-40. Sounds like it's just dirty
Old Jun 5, 2014 | 02:22 PM
js2krazy's Avatar
I did that about 2 months ago Gb, but i'll give it a shot again. thanks Ron i didn't clean the TB i'll do that as well but i still need to stop by LHT anyways. thanks everyone. will let you all know by the end of the weekend
greddy914
Mar 19, 2012 12:33 PM
s2000Junky
Mar 10, 2011 03:47 PM
tableskillz
Oct 18, 2008 04:47 PM
