OFF TOPIC VI
Originally Posted by Spa_Ap1,May 7 2007, 10:12 PM
So..........I have this noise.......not enjoying it so far. It's a squeaky, squeaky noise from the rear driver's wheel. It does it when I'm driving, and when turning right, but not left. Is it like a wheel bearing or something? It seems to be coming from the outside of the wheel like around the brake, but I don't think it's the brakes because it doesn't do it when I brake. Perhaps my rotor is warped? It doesn't shake when braking though.......Enough of my ramblings. Anyone else had anything similar? I'm sad.
Symptom of wheel bearing/hub issue: intermittent grinding/squeaking sound from wheel at low speeds when off throttle Sound increases proportional to speed until about 35mph when the sound goes away. Sounds almost like a warped rotor rubbing, but applying brakes does not affect the sound at all.
Looks live I've got some reading to do. Just in time for SESM too.
Maybe I can get everything I need before then.
Originally Posted by Spa_Ap1,May 7 2007, 10:34 PM
I'll have to double check about when applying the brakes. I checked the pads but they look like they've got plenty of meat left on them. Ohhh how I love (and yet hate) you technical forums.
Originally Posted by shivers,May 8 2007, 08:34 AM
Russ ... if you need another set of ears to help out, feel free to stop by on your way home from work.
I'm probably going to tear it down tonight or tomorrow and see if I can be sure that's what it is. Also, do you think I should replace the other side at the same time or would it be ok to leave it? Dude, lots of questions.....
Russ you better make sure that is the problem before you go ordering parts and renting equip.
Remember my situation????!?!?!?
Learn from my dumb ass mistakes.
Also is it a high pitched sound?
is there any vibration?
Better him then me
