Question CEL
Old Oct 25, 2007 | 06:10 AM
Pointman15's Avatar
Default Question CEL
Hey sorry i am in a rush and gotta run, but maybe you guys would know would your CEL come on when your oil gauge gets to 30%, im just worried cause i did get my first road kill yesterday, poor squirrel and just did not want that to be the reason like something went up into the engine or some freak accident??? i dont know, ill get back to this post gotta run.
Old Oct 25, 2007 | 11:09 AM
TheLoons12's Avatar
no the CEL will not come on. The oil light would come on if you lose oil pressure ...... unfortunatly thats about it unless there is soemthing very wrong. If thats the case the CEL WILL kick on and flash at you. If it does kill the car IMMEDIATELY and get it towed someplace.
I personally think its a bit rediculous that they have it set up when if you dont tighten the gas cap three click the CEL will come on but not if you are below 50% in oil. just silly......then again checking the dip stick on a regular bases prevents that.....but still.
Old Oct 25, 2007 | 11:31 AM
mattfeet's Avatar
Yea, the gas cap thing is a joke.
-Matt
Old Oct 25, 2007 | 12:29 PM
TheLoons12's Avatar
i know.....have it kick the mant. light. not the CEL. That should be reserved for only HOLY CRAP problems.
Old Oct 25, 2007 | 02:49 PM
Pointman15's Avatar
Okay so i went to autozone and got them to run a check on the CEL and pull the codes, they pulled P1172 twice, and P2a00 twice, they did not have a clue and told me to go to honda, but since it was already to late, i decided to come here next best thing.
So i found that this has been a problem with 06-07 they get this a lot and it has to do with this - via copy and paste
Ok, the air/fuel sensor is similar to an oxygen sensor, except that it tells the computer the exact air/fuel ratio of the exhaust, as opposed to the O2 sensor, which has a much limited range, and doesn't actually tell the computer what the A/F ratio is. What is happening is when the engine warms up, the moisture that has collected in the intake/motor/exhuast can contaminate the A/F sensor and cause it to burn out/malfunction. If your car doesn't have any problems, don't worry about taking it to the dealer. Most likely the problems are related to certain environmental conditions that are not experienced everywhere.
also in other terms i need to go to honda so they probably can replace my a/f sensor. I think it might be a result of maybe the difference from cali to here????
Old Oct 25, 2007 | 03:32 PM
raymo19's Avatar
You may want to run this by Slows2k in the Alabama forum. But if it were me with the car under warranty I'd let the dealer handle it until it becomes clear they can't handle it.
Old Oct 25, 2007 | 04:23 PM
mattfeet's Avatar
I wouldnt waste your time at Honda. Theyll try to charge you a rip to fix it if there is anything wrong AT ALL. I honestly think your car is fine, and I know sometimes there is a "whack the map sensor" fix for things. Search for that, and itll come back with good results. If nothing else, youd at least be alright to come up here on Saturday!
-Matt
Old Oct 26, 2007 | 04:45 AM
TheLoons12's Avatar
-Matt
the map wack "adjustment" was for earlier model AP1s as it related to the rpm dropping when idling, causing the car to sputter and at times stall.
If its under warranty id take it to Honda and let them deal with it.
Old Oct 26, 2007 | 12:37 PM
mattfeet's Avatar
Dang, mine does that a bit. Maybe Ill go give it a good whack.
-Matt
Frame_Runner__
May 19, 2008 08:33 AM
ej3ffrey
Jul 22, 2006 03:30 PM
bcohan
Jun 21, 2006 02:05 AM
slps2k
Jul 28, 2005 02:44 AM
docofmind
May 15, 2003 10:07 AM
