Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
Innovative diff mount install question
Old May 15, 2012 | 07:51 PM
HoustonNFR's Avatar
Default Innovative diff mount install question
This install was simple until I ran into a little problem.
What I'm trying to do and what comes with the kit.
Ok now I think this is how it's supposed to be installed.
But wait...let's take a closer look guys.
The stud only gos in about half way threw the nut... Am I supposed to run it like this??
It fits with out the inserts but last thing I want is sqeeking mounts.
Pleas chime In if you know what I'm doing wrong. I did think about it before I posed but couldn't figure out why it came up short like that.
Thanks fellow s2ks
Old May 16, 2012 | 06:58 AM
9krevvin's Avatar
Take som further away pictures and send them to me. I'll see if i can help you out.
Old May 16, 2012 | 08:21 AM
HoustonNFR's Avatar
I will do that. Thanks!
Old May 17, 2012 | 10:10 PM
HoustonNFR's Avatar
Compressed and this is as much as I get
Should I run it like this with no washer???
Old Aug 17, 2012 | 06:06 PM
s2000ellier's Avatar
I just installed these mounts as well and noticed the same thing as you. With the washers in place the 19mm bolt only threads on about halfway. How did you end up running your setup?
Old Aug 18, 2012 | 04:21 AM
HoustonNFR's Avatar
I just ran it without the washers. I Did not visually notice any anything wrong with the mounts or witness sounds coming from them after 2000 miles so Im sure it will be ok. When installing the rear passenger side mount there Is a possibility you will have fitment issues. When I did mines all 4 holes did not line up correctly so I had to upen up one of the holes to fully mount all 4 bolts into the sub frame.
You will love these once they are on
Old Aug 18, 2012 | 05:53 AM
Thank you sir!
Old Sep 29, 2012 | 10:50 AM
WootRWD's Avatar
sorry to bump an old thread....where did you get your diff mounts from?
Old Sep 29, 2012 | 09:47 PM
HoustonNFR's Avatar
Made by inovative and bought from eBay
Old Jun 25, 2013 | 11:23 AM
HDA's Avatar
HDA
I have to install these but I do not really feel like in a 95 degrees weather...
