Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
Transmission replacement
Old Aug 23, 2013 | 05:08 AM
Ascens1on's Avatar
Default Transmission replacement
I just ordered a transmission and clutch from another member here and hoping to arrive before friday, was wondering if any of you guys have experience changing out the transmission on the S, Ive done it on other cars just not the S yet and was hoping someone can lend me a hand otherwise i'm on my own haha. let me know if anyone interested in helping me out with this mini project.
Thanks
Old Aug 23, 2013 | 06:22 AM
SilverStreak476's Avatar
Research starter bolt removal and broken knock sensor... those go hand in hand. From my personal experience these were my 2 trouble spots:
Starter bolt:
Remove the belt. Remove top alternator bolt, and loosen the bottom. Then pivot the alternator out of the way. Youll need 18" of extension, swivel, and 14mm socket to remove starter bolt, being slow and careful as one slip can lead to a broken knock sensor... Once loosened LEAVE the bolt in the starter housing. Itll be a pain to get back. I was able to feel the bolt by hand from under the car. Feed the extension w/socket through under the manifold, then get under the car and place socket on bolt. Then you can start wrenching.
Top trans bolts:
Once drivetrain is disconnected, You will likely need to lower the motor a bit to access the top trans bolts. This is easily done by equally backing out the subframe bolts from the bottom of the car. There's 3 on each side, middle bolts are shorter and can be removed. The 4 corner bolts are long, and can be backed out safely. I had to back mine out about 4" (you may not need that much, i have innovative mounts) to get the clearance I needed. Go SLOW and you may find items that also need to be removed to go lower. I read youll likely have to remove the headers for access to a trans bolt. I'm turbo'd and found i had to remove full exhaust/turbo assembly bc it was hitting the frame. Your headers may also need removed for this reason as well, but I'm not 100%.
Just do some researching. All the info is out there. Any other questions feel free to ask
Sent from my Galaxy Slll
Old Aug 23, 2013 | 10:40 AM
V6 Donut's Avatar
I'm down... I have only done one so far, it was fun. Just Text me when you were wanting to do this. At the end of the month I should get my crx back from paint and well ill be tied up that weekend putting it back together. but should be free after that.
Old Aug 23, 2013 | 09:48 PM
Rivin2e's Avatar
Thanks
when we take it apart, can we keep doing it till we have enough extra parts to build a tranny?
Old Sep 3, 2013 | 05:36 PM
Ascens1on's Avatar
Replaced my tranny this past weekend after it completely went out. Clutch spring popped off :/ anywho new tranny goes unto gears like butter once again I'm very happy. Will be testing up my ikd tranny and provide pictures see what's bad and what isnt
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Old Sep 3, 2013 | 05:47 PM
_brandon's Avatar
Holy #$@5, what was it doing? Mine is in the shop for probably the same reason.. Check out my topic!
Old Sep 5, 2013 | 06:34 AM
Ascens1on's Avatar
it started with third gear grinds, then i couldn't downshift worth a f@#k unless i reved up then i was able to downshift then finally i wasn't able to go in ANY gear. this all happened in a 3-4 month span daily driven. i had already purchased a new used transmission knowing that any moment the current one would go out and the day my purchased one came my transmission went out lol.
Car Analogy
May 13, 2016 02:39 AM
dagle
Oct 12, 2014 08:25 PM
seansniper
Jun 20, 2012 08:35 AM
CaptinMorgan97
Oct 6, 2003 04:13 PM
