Texas - North Texas S2000 Owners North Texas S2000 Owners Club
North Texas Club
P0135 - Primary O2 Sensor
Old Feb 22, 2011 | 06:17 AM
davidnyc's Avatar
Default P0135 - Primary O2 Sensor
Anyone had this code?
Car is an '07, Intake/Header/Exhaust installed before I purchased.
I pulled the 7.5Amp to reset CEL (maybe didn't do anything...maybe pulled the wrong fuse or the O2 sensor did fail). I wanted to see if the light would go off and maybe come back on.
Should I unscrew and re-tighten the O2 sensor? Would this do anything? (besides waste my time).
Or just pony up the $300 and get a new sensor?
Old Feb 22, 2011 | 06:41 AM
00MUGENS2's Avatar
Mileage??
Id try warranty.
But either way, you will need a new one.
Old Feb 22, 2011 | 07:26 AM
rjones's Avatar
I had it come on Friday. cleared the code with an ODB reader and It has not come back yet after about 80mi.
Edit
mine was the secondary PO139.
You can fine it a lot cheaper than $300 online.
Read this.
https://www.s2ki.com/forums/index.php?showtopic=845976
edit 2.
On an 06+ I belive you need to use an ODB reader, but I could be wrong. If you don't have one O'Reily's loaned me one to clear mine.
Old Feb 22, 2011 | 07:36 AM
JS2k.com's Avatar
Sponsor
If it's still under warranty, they should cover this. Mina had the same sensor go bad and was replaced under warranty.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Feb 22, 2011 | 07:51 AM
rjones's Avatar
Here it is for $134, but check to make sure it's the right one.
http://frugalmechanic.com/auto-parts?q=234-9065
Old Feb 22, 2011 | 08:55 AM
davidnyc's Avatar
I am not sure it will be warrantied because of aftermarket header. I'll ask. Found the part for $180 @ rock auto.
Old Feb 22, 2011 | 09:23 AM
rjones's Avatar
I would clear the code and see if it comes back before spending the money on a new one.
Old Feb 22, 2011 | 11:39 AM
davidnyc's Avatar
Is there a way to clear the code without a code reader? I don't have one.
I checked on this site and one thread talked about pulling a 7.5 amp fuse. Did that and CEL is still lit.
Old Feb 22, 2011 | 11:42 AM
rjones's Avatar
O'Reily's will loan you a code reader that you can take home If needed. You just have to leave a deposit. The hardest part is finding the ODB2 port in the car, took us 10 min. to find it. It's under the dash on the right of the steering column, bring a flash light.
I think pulling the fuse only works on 2000-2005 cars.
Old Feb 22, 2011 | 12:16 PM
davidnyc's Avatar
Cool. I found the port (I have a Helms).
Thanks !!!!
