02-03 UK S2000s - rear defrost switch location
On 02-03 UK S2000s, I know that the rear window defrost switch was located on the armrest console. Was it located on the slot closer to the driver, or closer to the passenger?
And what switch occupied the other slot? Or was it just empty?
Thanks.
Thanks.
Originally Posted by motogp1,Mar 20 2009, 11:09 AM
The other one is the head light washer.
Originally Posted by motogp1,Mar 20 2009, 11:27 AM
My mistake , yes the above is for 01 , don't know what is in place of the washer switch on 02/03 model.
All I needed to know was where the rear defrost switch location was on the console. You said the 02-03 S2000 had the defrost switch nearest to the driver, but you have a 01. I didn't think the 01 had a defrost feature. Or were you referring to other 02-03 S2000s you've seen?
Thanks.
Originally Posted by motogp1,Mar 20 2009, 11:42 AM
I have 01 with hard top .
So... from the factory, your 01 S2000 came with a headlight washer switch on the passenger side slot. And then, either you or the dealer installed the rear defrost switch on the driver side empty slot on the console. Do I finally have this right?
