10yr service
Old Sep 21, 2010 | 12:19 AM
jimpom23's Avatar
Default 10yr service
My S is due it's 10yr service and having not been overly impressed with the main dealer services I'm taking it to the independent who does all the little bits on it.
It's only a minor service on this one but I'm a little nervous about the Oil Filter - I'm assuming it will be a generic one and after a quick search, a few have had problems in the past with the OEM one with regards to tightening, let alone a 3rd party one..
Am I best just getting the OEM one for him to fit with all the instructions on, I assume whatever filter he gets will be the right one to fit but I'm just a bit nervous?
Thoughts appreciated
Old Sep 21, 2010 | 12:31 AM
GREGSTERWIZ's Avatar
Yes
make sure it's the correct (larger) S2000 specific filter
part no 15400 PCX 004
Old Sep 21, 2010 | 12:34 AM
GavB's Avatar
Buy the OEM one. Give it to him.
Part Number/15400PCX004 (OIL,FILTER CARTRI) £13.18
Part Number/9410914000 (WASHER, DRAIN PLUG, 14MM) £0.36
Old Sep 21, 2010 | 12:35 AM
richmc's Avatar
The fitter does the tightening not the filter! The engine runs at a pretty high oil pressure. so the filter needs to be tight. There is a torque spec for it look on the tech faqs, also I remember seeing a home made mod involving a jublee clip and bit of metal fixed as a stop to prevent rotation, worth searching the treads if you are worried. Opie are a good source for oil & filter.
Old Sep 21, 2010 | 12:43 AM
Si2k's Avatar
Turning it 7/8th of a turn after the gasket meets the block.
I did mine last week and its pretty easy as each of the 8 'sides' are numbered so you know exactly how much to turn it.
Old Sep 21, 2010 | 01:07 AM
jimpom23's Avatar
Thanks all...
My local dealer has them in stock and they are cheaper than I first thought so will get those I think...
The other option as above is a service pack from opie, but I would still have the same concerns about an OEM ''approved'' filter and the tightening etc so will probably stick to Helfrauds for Oil and Honda for filter...
Old Sep 21, 2010 | 01:27 AM
mikey k's Avatar
Be careful with my old car
Take it to Garage R he's not that far way from you and uses the OEM filters
Old Sep 21, 2010 | 02:37 AM
Si2k's Avatar
Get an OEM from Honda
Dappa
Dec 30, 2010 08:11 AM
Vixen
Jun 19, 2010 01:03 PM
CarbonS2000
30
Jan 20, 2008 07:37 AM
Sniper_S2K
Sep 22, 2006 01:32 PM
Si2k
Jul 3, 2006 05:08 AM
