1st to 2nd shift tight - when cold only
Old Mar 8, 2007 | 04:46 AM
gixermark's Avatar
Default 1st to 2nd shift tight - when cold only
Hi guys,
is this a normal (ish) thing on the s2000 ?? it only ever happens when the car is cold... when up to normal temp the shift from 1st to 2nd is smooth... i woudln't say it crunches when cold.. more that its very stiff/tight...
would fresh gearbox/diff oil help or could it be something like the linkage being affected when the engine etc gets warm ??
Mark.
Old Mar 8, 2007 | 04:50 AM
Neil.H's Avatar
It's normal, new gearbox oil can definitely help a bit.
Old Mar 8, 2007 | 04:52 AM
Lurking Lawyer's Avatar
"They all do that, sir"
Old Mar 8, 2007 | 05:01 AM
lower's Avatar
It is normal. Both of mine have done it to some degree, my new one more than the first. I just slow down the 1st to 2nd change until the gearbox oil has a bit of heat in it.
Old Mar 8, 2007 | 08:26 AM
gixermark's Avatar
excellent... i guess the gearbox tollerances might be quite tight then...
I'm planning to change the Gearbox & Diff oil etc. this spring.. and fit teh hub nuts from the GB many many months ago !!
Mark.
Old Mar 8, 2007 | 08:28 AM
motogp1's Avatar
mark go for motul gearbox and lsd oil very highly rated
MOTUL OIL - LSD Oil 90PA
MOTUL OIL - 75w90 Fully Synthetic Manual Gearbox Oil
Old Mar 8, 2007 | 08:31 AM
gixermark's Avatar
thanks will take a note of that...
Mark.
Old Mar 8, 2007 | 08:42 AM
RUSS H's Avatar
Or Redline gear oil, highly rated on some US threads.
Iv'e changed to this on my 02 and 04 S makes a difference.
But yes they are stiff when cold and I cant understand how
in the past the S2000 box has been rated the worlds best.
Its far from it, just good when warm.
Russ.
Old Mar 8, 2007 | 08:49 AM
mikey k's Avatar
As MT says "they all do that sir"
Hence why I get the dealer to do the gearbox and diff oil at EVERY service.
Old Mar 8, 2007 | 10:40 AM
Badger's Avatar
