2007 engine / sensor / valver cover differences
Old Jan 24, 2009 | 06:44 AM
nicholasbartleet's Avatar
Default 2007 engine / sensor / valver cover differences
Hi Guys,
I have a problem. To cut a long story short, my engine blew up in my MY00 s2000. I managed to track down a 2007 engine with 6k on it. The engine arrived and looks clean. I was advised that the only difference was the drive by wire and the inlet manifold, which i plan to switch with my original and looks to be an easy swap.
The Problem?
We just noticed that there is only one engine sensor on the 2007 valve cover. The 2000 engine has 2. We had to lift the valve cover to see what differences lurk benieth. It would appear that the only visible difference are the timing sensor plate/disks that reside on the end of each cam. We have checked and these are interchangeable and therefore we could switch them and also the valve cover on the new engine to the old cover to match so that the original loom will plug in with no problems. Does anyone know if this would work?? Or if we are likeley to encounter any more problems?
I would really appreciate any help or if someone could point me in the direction of someone who may know.
Thanks
Old Jan 26, 2009 | 01:48 AM
Anyone?
Old Jan 26, 2009 | 01:55 AM
E4RTH WORM JIM's Avatar
I'd post a link to the thread in the "under the hood" forum on the main site. Hopefully someone will know about the 06/F20C.
Good luck with the swap
Old Jan 26, 2009 | 02:14 AM
Thanks.
I have posted a link there as well, with no luck I it looks fairly simple so i think i will have to go for it and hope i don't run in to any problems.
Old Jan 26, 2009 | 02:31 AM
lucky77's Avatar
Nicholas, as well as the different cam sensor and trigger wheel in the valve cover it also has a different TDC sensor and trigger wheel on the crank, which you should have on your new engine. Im not sure how the old ECU will deal with the new inputs though
Good luck, hope it works out.
Old Jan 26, 2009 | 08:08 AM
[QUOTE]Nicholas, as well as the different cam sensor and trigger wheel in the valve cover it also has a different TDC sensor and trigger wheel on the crank, which you should have on your new engine. Im not sure how the old ECU will deal with the new inputs though
Old Jan 26, 2009 | 08:35 AM
lucky77... do you think it will be fine with the new 2007 crank, while only changing the 'crank pulser' becuase apparently the codes for the crank are different.
It should run fine on the old ecu as long as the right pulser and sensor is on it shouldn't it?
Old Jan 26, 2009 | 08:42 AM
chrisr111's Avatar
Nicholas, if the first 7 digits of the part numbers for the cranks are the same and only the last three digits differ e.g.
XXXX-XXX-001 and XXXX-XXX-003
this usually indicates a minor incremental improvement and not a totally different part, so should be ok.
If the part numbers are totally different you might have a problem....
HTH
Chris.
Old Jan 26, 2009 | 10:34 AM
HTH
Well the crank and the crank pulser have incremental number changes, but i have been told they are not the same i.e just new manufacturers etc' and that they are both slightly different parts. I think my only option now is to try and change the pulser and put the engine together and try it.
I have found a thread where americans have done just this with the f22c engine with f20c car and it has worked fine... so i am keeping my fingers crossed.
aznsupastar
Aug 29, 2017 04:36 PM
dragonash
Apr 27, 2014 09:05 PM
yongz
Mar 24, 2012 03:29 PM
nicholasbartleet
Mar 11, 2009 02:20 AM
