ABS light
Old Jun 4, 2011 | 10:57 AM
s2konroids's Avatar
Default ABS light
Gents,
I get an ABS light at high speeds (only happens at high speeds), now I've had it for a while but just forgot about but I'll be off on an airfield day soon so i would like to get it sorted.
Where do i start other than firstly getting the code read?, i think it could be something to do with the ribbed ring and NOT a sensor?
Can i get/clean the sensors without removing the wheels?
I'd like to look under the car but not 100% sure what i should be looking for, does anyone have any suggestions?
Thanks in advance
Old Jun 5, 2011 | 06:27 AM
s2konroids's Avatar
Update,
All sensors and pulse rings look fine, no cracks or missing teeth. Distance between sensor and ring is within tolerance too.
Any ideas, before i get the code read?
cheers
Old Jun 5, 2011 | 07:46 AM
Joeh's Avatar
You can read the code with a paper-clip on the ODBII
I would say a bit of wire brush on the abs rings would do the job - or a clean on the end of the sensors..
Joeh
Old Jun 5, 2011 | 07:51 AM
s2konroids's Avatar
Joeh,
Did exactly that mate, wire brush, brake cleaner and feeler gauges used - no cigar though, light still comes
on.
I'm pretty sure the paperclip method only works on JDM cars ?, not treasure island UK cars. I know for sure the paperclip method doesn't work for reading CEL codes.
Is the ABS socket different from OBD2 sockets?, as i notice the normal OBD2 port but a green socket too.
Cheers
Old Jun 5, 2011 | 07:56 AM
Joeh's Avatar
You could be right about JDM cars as I haven't had a chance to try it on a UK one yet..
Still must be worth a try right? Join pins 9 & 4 AFAIK- Pop out if you have a few minutes and give it a go
OBV long flash = +10 and quick flash = +1
I know it works on USDM cars to say the least, so UKDM should be fine (hopefully)
Joeh
Old Jun 5, 2011 | 07:57 AM
Joeh's Avatar
Just saw your edit - I managed to get ABS, PAS and EMS codes from the ODBII (paperclip method) so you shouldn't need to use anything else
Joeh
Old Jun 11, 2011 | 01:56 PM
s2konroids's Avatar
Anyone got any ideas, i replaced the sensor and still no joy, any ideas?
Could be a wheel bearing, but how can i tell?, again pulse wheel and sensor are fine.
Cheers
Old Jun 11, 2011 | 02:50 PM
GaryB's Avatar
What are your tyre sizes and what is tyre wear like on each wheel?
Old Jun 11, 2011 | 02:52 PM
s2konroids's Avatar
17's mate, and even wear the geo is spot on as the tyre pressures too.
cheers
Mocky
Jul 25, 2013 02:52 PM
sp00led
Jul 25, 2011 03:43 AM
chikin tities
Jul 11, 2009 12:14 PM
Bravnik
Mar 4, 2006 06:01 PM
ImportSport
Apr 7, 2004 11:12 AM
