ABS Sensor reading
Old May 21, 2013 | 02:06 PM
Toms1989's Avatar
Default ABS Sensor reading
Evening all
As per title, was wondering if anyone knew the normal ohm readings of the ABS sensors on the S2K? Got a duff one somewhere on mine so going to track her down
Cheers!
Tom
Old May 21, 2013 | 02:40 PM
davemr2's Avatar
i all have a sensor down i think, the EPS light is flickering on and off Grrrrrrrr
So i need the ohms readout
Old May 21, 2013 | 03:11 PM
Daytona-Dave's Avatar
900 to 1200 on average, main thing is they are roughly the same for each pair check each front, then check the rears, you can also check for voltage with a multimeter by turning the wheel, or if you know someone with a scanner that will pin point the fault
Old May 22, 2013 | 02:51 AM
Toms1989's Avatar
Cheers Ray I'll give it a shot and let you know how I get on
Old May 22, 2013 | 01:05 PM
Toms1989's Avatar
No reading what so ever, guessing it's had it, the other side was 1260ish
Struggling to find one without paying the bloody earth
Old May 22, 2013 | 01:29 PM
Try these Tom, don't know which side you want http://www.ebay.co.uk/itm/honda-s200...item2c6cd80006
Old May 22, 2013 | 02:00 PM
Toms1989's Avatar
Sound, is that about the going rate for one of them?
Genuine honda one just a shade over £160 + vat.... can't get one through my work!
Old May 23, 2013 | 01:34 PM
Toms1989's Avatar
Sorted! Soldered either ends together tidy and works a treat!
Old May 23, 2013 | 01:49 PM
Why what had you done? trapped it or stretched it
Old May 24, 2013 | 01:07 AM
Toms1989's Avatar
Not me! Mate did when raising the subframe back in place
-=Theoscion=-
Sep 9, 2010 08:43 AM
milkman2089
Jan 27, 2010 07:39 PM
cdn_ap1
Aug 19, 2009 03:03 AM
Asura
Aug 2, 2007 08:17 PM
whtdc2
Apr 18, 2002 04:15 PM
