Ac delete
Old Nov 16, 2014 | 03:45 AM
Carbon S2K's Avatar
Default Ac delete
Hi people before I start I just want to say have done a search
I have removed most of the ac parts under the bonnet but I would like a couple of pointers to finish this please.
1) I want to keep the heater function but is there anything to remove out of the box under the dash n/s or do I just disconnect the two hard lines?
2) I have a short aux belt but have never done this before so a how to on this would be ace.
Thank you for the help guys.
Old Nov 16, 2014 | 04:37 AM
Ghost-Reaper's Avatar
When I did this with my old Civic Type R I just capped the lines at the firewall and left the unit inside. It was way too much work to dig it out of the heater system and didn't weigh that much to warrant the time.
Spanner on tensioner and move it release tension, shorter belt should follow the same routes minus the AC. Search for photos of the engine
Old Nov 16, 2014 | 06:48 AM
weatyGT's Avatar
We did this over the weekend. I figured I have aircon as standard... button is just by the handbrake :-)
Removing the dash is required if you want... im capping the hard pipes off where the pipes go through the fire wall though, removing the dash is a big job!
Google toda light weight pulleys... youll find a nice image of how the shorter belt goes. Its self tensioner so no worries with belt tension.
Old Nov 16, 2014 | 07:52 AM
Carbon S2K's Avatar
oh no I was hoping I could remove the hard lines without the dash out
Thanks for the help people
Old Nov 17, 2014 | 09:34 AM
Krisbuc's Avatar
Hard lines can be removed all the way to firewall then it's up to you if you want to remove dash if not just leave as is that's what I did
Smurf_9K
Feb 1, 2013 08:04 PM
TG Racing Japan
Mar 8, 2012 02:13 PM
R3DS2K
May 19, 2008 11:16 AM
shotiable
24
Oct 18, 2007 09:45 PM
