Additional New User FAQ - forget it
Old Oct 7, 2009 | 12:59 AM
Rob88's Avatar
Default Additional New User FAQ - forget it
-Deleted-
Old Oct 7, 2009 | 01:38 AM
mikey k's Avatar
I'm with you on this
On the roof thing there are several common areas
side seals leakaging - clean and silicon grease usually sports this
latches/stikers wearing - links to striker plates and latches adjustment
frames wearing holes - link to "lizard skins"
splits in plastic screens - link to decewnt hood replacement thread
Is it a GT? - link to HT fitting kit thread of some sort
On the parts front there is a good US site for part nos majestic honda IIRC
Is there anything else that should be added from a new used buyers perspective?
Old Oct 7, 2009 | 01:41 AM
loftust's Avatar
I think it is worth mentioning that the older cars do burn oil (up to 1 litre per thousand mile is acceptable). Therefore, check your oil religiously after filling up, making sure the ground is flat and level...as most forecourts are, waiting at least 5 minutes before the engine has been turned off.
As for part numbers: http://www.hondapartsnow.com/oem/honda-s2000-parts.html
Bear in mind this is a US site, so is for LHD. If in any doubt, your dealer can email you the relevant IPC page so you can identify the relevant part(s).
I also think that a brief insight into Geometry and seized adjusters should be included.
Tyre Recommendations 16" (Recent thread):
https://www.s2ki.com/forums/index.php?showtopic=735069
Idle Problems:
https://www.s2ki.com/forums/index.ph...&f=25&t=467545
Old Oct 7, 2009 | 01:42 AM
Vixen's Avatar
We do seem to be overrun with oil and tyre questions particularly, think this will be a big help (if people can find/search for it )
Old Oct 7, 2009 | 01:47 AM
loftust's Avatar
Rob...If you need a hand to compile this and present it in a organised, easily accessible manner...I'm happy to help
Old Oct 7, 2009 | 01:53 AM
FistralG's Avatar
I think a glossary of abbreviations would be helpful too. Quite often people type acronyms to save time but to those not in the know they are meaningless! e.g. IPC???
Old Oct 7, 2009 | 02:05 AM
Rob88's Avatar
-Deleted-
Old Oct 7, 2009 | 04:20 AM
Shopman's Avatar
No idea if this would work...
The thing that makes the FAQ frustrating is that you cannot correct or update the info only add to the bottom of the FAQ unless of course it is your own post .
Would it be possible to set up an FAQ for the S on Wikipedia that we could then all update and add to, an worldwide resource for all S owners which could be linked to from here.
Old Oct 7, 2009 | 04:28 AM
LTB's Avatar
LTB
Good idea until some twunt puts absolute rubbish in it.
Old Oct 7, 2009 | 04:29 AM
lovegroova's Avatar
I wouldn't say that the bolts "tend" to be stuck, "might" or "can" be stuck would be better. The issue is a bit overstated IMO. How many owners have "had" to replace all their bushes and bolts?
Most people are affected by one or two at most, and it's certainly worth explaining that getting the vbolts greased at the earliest opportunity is definitely worthwhile.
