Advice needed
Old Feb 9, 2015 | 07:55 AM
Ian Lillystone's Avatar
Default Advice needed
I've tried to ask this before but with no luck.
I've got a loud knocking noise that I can hear clearly from inside the car, that appears when the car is up to temperature but idle. When I Rev the car slightly it goes, and them comes in again 20-30 seconds after it settles at idle again.
When the car has been driven for a few miles and is properly up to running temperature, it goes or maybe Is still there but only very quietly, and I'd really have to strain to hear it.
The car is running faultlessly and has not thrown up any fault codes etc. it was recently services at 54k and has had valve clearances adjusted.
Any advice on what it could be or similar experience would be massively appreciated. I'm really worried it's my bottom end?
Old Feb 9, 2015 | 08:20 AM
kw_21's Avatar
Any help https://www.s2ki.com/s2000/topic/970...sound-at-idle/
Old Feb 9, 2015 | 08:29 AM
MichaelParkinson's Avatar
Come along to the NE Meet this saturday at Silverlink and see if any of us can shed any light
Old Feb 9, 2015 | 08:30 AM
chrispayze's Avatar
And mine...
https://www.s2ki.com/s2000/topic/1103994-/
Old Feb 9, 2015 | 08:41 AM
NicoS's Avatar
I was just about to say, come along to the meet on Saturday and we can try help with a diagnosis
Old Feb 9, 2015 | 09:03 AM
Where is it?
Problem is, you probably won't be able to hear it once I'm there.
Old Feb 9, 2015 | 09:04 AM
Originally Posted by kw_21
Thanks for that mate, seems like it could be a very common problem?
With mine though, you can't here it under the bonnet, just seems like from the inside. I'm confused!
Old Feb 9, 2015 | 09:17 AM
NicoS's Avatar
Originally Posted by Ian Lillystone
Where is it?
https://www.s2ki.com/s2000/topic/111...#entry23498891
Old Feb 9, 2015 | 09:24 AM
Originally Posted by NicoS
Originally Posted by Ian Lillystone' timestamp='1423504983' post='23499513
[quote name='MichaelParkinson' timestamp='1423502999' post='23499452']
Where is it?
[/quote]
Where's silverlink mate? Is that North shields?
Old Feb 9, 2015 | 09:32 AM
NicoS's Avatar
It is just on the other end of the Tyne tunnel. Not as far as North Shields
