Air Con problem...
Air con didnt appear to be working, so booked in for a re gas, guys have come out to do it, pressure tested the system and said its fine loads of gas in there, but the compressor is not kicking in as it should it does when you start the ac but then turns off.
They reckon there is some kind of temperature sensor in the system that is at fault- reccomend sending it to the dealer to get a diagnostic done.
Does anyone have any clues as to what this could be? Past experience?
Thanks
Tom
Thanks
Tom
for the ac compressor?
i think it must be temperature related because the compressor starts for about 20 secs when you flick the a/c on then shuts off. The green light is also on inside the vehicle and stays on.......
it must be some kind of temperatue sensor
