Alignment Bolts.
Now that we're keeping the new car my plan is to get the bolts greased really soon, is there a way I can I pop these out and copperslip them, refit and then get the alignment checked/set a few days later, or should I book the car in and give the fella a hand to remove/grease/refit the bolts and get him to set it up right away.? Just trying to save a couple of hours labour.
Thanks. What I meant was, can the alignment go out when I remove the bolt/s to grease them, or does something else move.? Don't want it to be miles out even for a short time between greasing and getting it on the ramps and set up. Ta.
Originally Posted by mattg4321,Jun 10 2009, 07:39 PM
The alignment will be out after you remove and refit - you need to mark the positions before you remove them and refit as close as possible. Get it properly aligned asap afterwards.
Use the markings as a guide, get them all done and then drive straight to Geo
I was wondering a similar thing. I use my car daily for an 80 mile commute.
I'm planning on fitting coilovers at some point in the future but to save some of the pain when I do, I was going to remove some bolts, one at a time beforehand, grease and replace over the course of a few weekends.
Question is, what can I do beforehand without taking something off that means geo needs urgently doing?
Originally Posted by mikey k,Jun 11 2009, 01:09 AM
Don't forget to bolt them back up in postion with the suspension under load!
Never occurred to me but obvious when you think about it...
