Alinement...
Old Jan 18, 2008 | 12:48 AM
jonner's Avatar
Default Alinement...
Is getting an s2000 tracked the same as gettng any other cat tracked..
I'm assuming that tracking is the same as alinement...
Not too well up on this stuff...
Any help appriciated..Just got new shoes fitted and want too make sure that they dont get worn on the insides...
Old Jan 18, 2008 | 01:32 AM
GavB's Avatar
The cost will give you an indiction of what they are going to check/adjust, but generally when tracking is checked only the toe positions of the front wheels might be checked and adjusted, again dependant on price/location the accuracey of the equipment used will varey.
If you ask for tracking, it would be unlikley for you to receive a full 4 wheel alignment.
Best bet is if you are shopping around, ask for the price, what parameters are checked and what they use to do it.
Old Jan 19, 2008 | 06:50 AM
mikey k's Avatar
Tracking is front wheel alignment only
You actually need 4 wheel alignment on the S
Old Jan 20, 2008 | 11:25 PM
jonner's Avatar
Cheers for the info folks....
fltsfshr
Oct 4, 2011 04:35 AM
LoudMusic
Aug 25, 2008 08:38 PM
Badapple
Jan 15, 2005 05:32 AM
