Any problem leaving the S standing for a while
Old Feb 13, 2009 | 02:06 AM
  #21
NineBolts's Avatar
I had my old MG garaged and left for over a year. Only problem was the clutch jammed. So I should of stored it with the clutch pedal depressed according to some sources.
I had to free it up by starting it in gear, then standing on brakes and throttle. It was fun but it worked
Old Feb 13, 2009 | 02:30 AM
  #22
oxhouser's Avatar
Its best to fill your clutch housing with oil
never sticks after that
Old Feb 13, 2009 | 02:38 AM
  #23
s2konroids's Avatar
I dont have a scanguage.
I will leave the car in gear only, and my father will now drive it once a week.
Regarding warmup, when i first start the car i let it warm up for a wee while then drive off.
O/T: But a friend of mine swore to keep TVR's sweet you warm them up first, rather than turn the key then drive off 5 seconds later.
Thanks for the replies.
Old Feb 13, 2009 | 03:04 AM
  #24
Si2k's Avatar
Originally Posted by Bassoctopus,Feb 13 2009, 09:14 AM
Yes, but mine's been garaged for 4 months and has only been driven twice in that time
I've done all the other stuff, but been starting and running it for 20 minutes once a month
Fair enough, I have no experience of leaving my S2000 in a garage. Mine gets driven whatever the weather, sun or snow.
Old Feb 13, 2009 | 03:38 AM
  #25
Bibbs's Avatar
Tray of cat litter in the footwells
Old Feb 13, 2009 | 03:42 AM
  #26
C7BLE's Avatar
I'm scared to try and start mine...
Old Feb 13, 2009 | 03:58 PM
  #27
Mans Best's Avatar
Originally Posted by oxhouser,Feb 13 2009, 09:25 AM
its up to you, a lot of oil has small amounts of water emulsified in it due to condensate if its left standing it seperates, as you say it might be extreem but for me the cost of an oil change if its left standing for say 12 months is worth paying for peace of mind. same goes for brake fluid unless its synthetic the normal stuff is hydroscopic and can lead to piston corosion if they are left
not sure i would be happy wedging the clutch open and leaving the hydraulics under load for an extended period.
I suggest you read this post again - I thought the question mentioned 5 weeks and that's suddenly become 12 months?
I think you'll find normal brake fluid is hygroscopic and it sits in the same brake lines whether the car is moving or stationery.
Clutch hydraulics "under load" - I sometimes wonder if we think we drive a car built in the 1920s from plasticine or bakolite
Old Feb 16, 2009 | 09:23 AM
  #28
s2konroids's Avatar
Car started up fine, so much for me thinking the battery was crap a week and half on and no battery probs
Old Feb 16, 2009 | 01:31 PM
  #29
composite guru's Avatar
Mines been laid up since the start of november and i've only turned it over once. As Simon says, it does more harm than good keep starting it and not putting any load on the engine as the oil pressure is not enough on idle. I have turned the engine over but only run it for a min just to let the parts sit in a different position.
I also have tyre blocks for the flat spot problem and a CTEK battery conditioner on it full time too.
I'm really looking forward to the end of March.
Old Feb 16, 2009 | 10:44 PM
  #30
Bassoctopus's Avatar
I know how you feel.
In fact since mine is still taxed I was sorely tempted to give it a blast on Sunday when it was dry and sunny. Problem was the salt still lying on the road.
It's such a chore running the Teg beater too
