Batteries.
You can check if a battery is charging properly or not.
Remove the caps/cover over the cells and put it on charge - if there are no bubbles rising from the plates during this process, the cell is stuffed.
(take care - no naked flames etc, wear eye protection)
The Optimate charger I use only has an output of 1 AH, but it I leave the S on charge whenever it is parked in my garage - I only use the S over weekends. The Optimate is also an "intelligent charger", i.e. it can not overcharge, and assists in desulphating the battery plates. I use these conditioning / intelligent chargers on my m/bikes, and vehicles .. they really do extend the life of batteries in vehicles that are not used regularly.
The C-Tek range of chargers are also excellent ... I use the big XS25000 model on the 3 x 105 AH batteries installed in my Land Cruiser. This model has an 8-stage charging / recond / maintenance mode cycle. I never have warm beer when in Namibia / Botswana in 50 deg C ambient temperatures!
The smaller C-Tek chargers would be great for the puny 35 AH battery in the S2K.
Originally Posted by Dembo,May 29 2007, 09:04 PM
it went flat again at CoG what with having the brake lights on for some time.
During the winter it would go flat in a week if I didn't use the car
Connecting a conditioning charger with the car's electrics still attached goes against the advice in the handbook, namely, to disconnect the battery when using any type of charger. Having said that, I don't, and it seems that few owners on here do either. Is this just an @rse-covering warning on the part of Honda or is there a real danger of doing some damage?
I bought the C-Tek XS800 in the end. I left it for 8 hours this afternoon, and after that the car started fine. Seems like a worthwhile bit of kit to have.
Where does everybody connect these things to? Reading the instructions (after I'd used it ), it's fairly specific about connecting the -ve to the chassis and not the battery, which is odd. I just stuck the clips on the battery.
Anybody think of an issue there?
It even came with a loop connector which you can attach to the battery terminals as a permanent fitting and just plug in when needed - not sure why they'd ship it with that if you weren't supposed to connect to the terminals.
But I have often attached both clamps direct to the battery (carefully though - no sparks ... )
