BIG Alarm Problem
Old Feb 22, 2011 | 06:51 AM
K6Nix's Avatar
Default BIG Alarm Problem
Hi all,
I need some help please!
My battery has been disconnected and on trickle charge for a couple of days.
Now when I reconnect the battery, the alarm sounds - problem is, when I press the keyfob to cancel it, nothing happens!
When I've done this in the past, I have had no problem.
I've read the FAQs, Ive downloaded the Thatcham Alarm instructions, but to no avail.
The alarm battery backup has clearly drained as when I disconnect the battery while it is wailing, it stops after 20 seconds or so.
BTW - the keyfob does glow red when pressed so there is still some power in there.
Has anyone any ideas how I can get the system to talk to my keyfob again?
Old Feb 22, 2011 | 07:47 AM
Nick Graves's Avatar
Try e-mailing Hamilton & Palmer who made the alarm; they're quite helpful.
It probably requires a reset or a new battery but they'll know.
Old Feb 22, 2011 | 08:55 AM
s2konroids's Avatar
Mine has done that, but only if its flat as a pancake. After its been charged up and used, it fine.
Old Feb 22, 2011 | 09:25 AM
Kitesurfer s2000's Avatar
Happend to me 4 years ago got it towed to honda and they took all the alarm fuses out.
Old Feb 22, 2011 | 10:16 AM
Nottm_S2's Avatar
my (original) alarm goes off when i've washed the car lately
or when it's rained
the funniest thing is i can just drive off..
Old Feb 22, 2011 | 12:15 PM
Probably water in the (corroded) bonnet switch. I soldered mine back together, it was so rotten.
The 'Lude one occasionally goes of when you unlock it. Or sometimes when you try to start it.
Stupid bloody thing.
Old Feb 22, 2011 | 12:26 PM
Dracoro's Avatar
Try the following (the alarm may be going off all the time until the last step):
Key in ignition
Disconnect battery 30 secs (then reconnect - I think)
Remove key
Shut door
Click lock on remote 3 times
Click unlock once on remote
It may then be all OK (for a while).
THEN you still need to contact H&P (if it's an H&P unit) and describe to them what's been happening as it will probably fail again soon.
Old Feb 22, 2011 | 12:58 PM
K6Nix's Avatar
Thanks for your advice guys.
I've emailed H&P as suggested. It's been passed onto a 'techie' to ge back to me.
I'll post the results.
Thanks Dracoro, I'll give it a try. (the eardrums have been subjected to worse so far!)
Old Feb 22, 2011 | 02:39 PM
Nottm_S2's Avatar
i'll take a peek Nick.. fugging annoying
Old Feb 22, 2011 | 10:59 PM
Rob88's Avatar
I had a similar problem.
I have two fobs, one of them did exactly as you describe, but when I grabbed the other fob it worked fine.
I've since been unable to get the second fob to work.
If you have a second fob try that.
