Bolt in crossmember
Bolt in crossmember
Hello guys, I have removed my oem engine bay cross member ready to install a bolt in version.Can anyone point me in the rite direction
as to material choice?I have no idea how much load this is under when cornering so not sure how strong to make it, I mean I want both strong and
lightweight if possible.
1)3 inch round tube.......what wall thickness tho?
2)mild steel tube? Seamless mechanical? Or even aluminium?
Any advice would be great thanks.
Both good shouts, most of the pictures I've seen and articles I've read have been done with tubing then bolted in place. Its common i believe when doing an LS swap? Search this forum as i believe a guy on here put a custom tube one on while doing an LS swap.
That is simply incredible!
Ally scaffold with end fittings may be an idea to look at
