Bottom end
Old Feb 10, 2015 | 08:15 AM
Ian Lillystone's Avatar
Default Bottom end
Can anyone give me an idea if the bottom end was failing in anyway, if it would throw an error code and cause noticeable difference in performance?
As some may have read, I've got a knock/rattle/ticking which is prominent from the inside of the car and can't be heard outside.
Desperate to know what it is
Old Feb 10, 2015 | 08:17 AM
Ultra_Nexus's Avatar
Might be worth posting a vid of the noise.
Old Feb 10, 2015 | 08:25 AM
I've recorded the noise, but the trouble is it sounds much worse than it actually is, it's literally all you can here through the iPhone, if that makes sense, and it sounds worse than it is.
Plus, I've no idea how to post on here since I can't use tapatalk for some reason?
Old Feb 10, 2015 | 09:01 AM
Toms1989's Avatar
Bottom end rattles are usually diagnosed as the sound is inconsistent as the bearing spins.
Floppy
Dec 3, 2011 01:03 AM
JohnEan90
Mar 6, 2010 11:53 PM
dparm
Oct 24, 2008 10:02 AM
Jakup
Mar 29, 2007 09:24 PM
