Brakes over heating
#21
The front brakes on an S2000 are exactly the same as on an EP3 Civic Type-R
Go and get some low mileage replacements as they'll be as common as muck.
Having had a look on ebay, they seem a bit costy. I got a pair from Car Transplants for £110 from a 2006 model that had done 13k miles.
As for Bluestuff.....
I thnk you may end up killing the discs with them. Racing fluid, whilst good, has a much shorter life than normal Super Dot4. As long as you change it every 6 -12 months, it'll be worth having.
Kwik Fit...
£231 for something that would have taken me an hour and cost about £120 in parts.
Kwik Fit...
#22
Originally Posted by Spies' timestamp='1317331317' post='21024030
If it was the pads simply fading, the pedal wouldn't go soft, you just wouldn't stop as effectively.
#23
Kwik Fit...
Kwik Fit...
I was reading somewhere about bluestuff that they will work with oem discs and won't effect them much. I don;t mind changing discs as long as they last over 5k. I don't mind changing fluid either but most people who have used super blue racing fluid they say it last up to 12 months etc
#25
#26
I did a bit more "research" this morning and gave the brakes a hammering then stopped the car - the NSR was smoking a bit so it does look like a calliper's stuck
Any ideas how much I should expect to pay to get it replaced? Also - if anyone has any recommendations for a decent indy garage in the Pontypool/Cwmbran area (South Wales) that would help a lot. I've come across r-motion.co.uk but havent heard much about them so not sure if theyre any good or not.
Thought Honda's were supposed to be reliable
Jeff
Jeff
Anyway, check the link below, £250 for the pair (replace both as the other will be on it's way out) and a £25 (call it £15 as it'll be about £10 postage) refund on the old units.
http://shop.instant-shop.com/JRT-Aut...no3070649.html
It's a DIY job if you like but any mechanic will be able to do it.
