Brakes at the Ring
Old May 4, 2010 | 01:46 AM
StormS2K's Avatar
Default Brakes at the Ring
Am going to the ring in a couple of weeks and was planning to replace my brake pads with a new set of OEM pads before going.
My question however is how will the OEM pads stand up to a lap of the ring? This will be my first time driving on the ring so am going to be keeping it fairly steady.
If they aren't going to stand up to a lap what are the recommended alternative? DS2500's? I don't want to spend a fortune though...
Old May 4, 2010 | 01:53 AM
Rogan's Avatar
I'm going to the ring on the 24th june, i've put EBC yellow stuff pads in mine with ultimax disc's it made a fantasic change to mine!
Old May 4, 2010 | 02:04 AM
lovegroova's Avatar
It all depends on driving style.
Having said that, last summer I met a chap who'd spent a day at the ring, and managed a day and a half at Spa straight afterwards before his rear brakes ran out.
So it's certainly do-able.
Old May 4, 2010 | 02:39 AM
StormS2K's Avatar
Just seen these and these at Camskill.
Would they be a decent upgrade over the OEM pads?
Old May 4, 2010 | 02:52 AM
lovegroova's Avatar
Some people use them, but apparently they squeak a lot.
The OEMs are fine (and a lot cheaper) if you are taking it "steadily".
if the search is working, try a search for "Mintex 1144" - you'll get a lot more info.
Old May 4, 2010 | 02:54 AM
StormS2K's Avatar
Well steady-ish
I'll stick with OEM pads this time around and maybe upgrade for next time.
Thanks for the help
Old May 4, 2010 | 03:00 AM
lovegroova's Avatar
No problem.
Just make sure they are relatively new - get them fitted a month or so before to ensure a decent bedding-in process.
Old May 4, 2010 | 04:10 AM
tej's Avatar
tej
I am doing the same in the next couple of months.. front discs and pads are new.. in fact, new pads all round so I'm going to stick to OEM and take a spare set of front pads with me in case...
Much cheaper to replace the front pads when needed than upgrade to a set of aftermarkets for the sake of one trip for me.. and I don't have any issues with the OEM pads, they may fade a little earlier on a track, but they have good bite from cold on the road which is far more important to me
Old May 4, 2010 | 04:21 AM
lovegroova's Avatar
I'd take a spare set of rear pads as well, they tend to suffer more than the fronts do as they aren't cooled as well.
Old May 4, 2010 | 08:30 AM
tej's Avatar
tej
Thanks for the heads up
