Broken Pump
Old Dec 1, 2009 | 07:39 AM
pedrobaby77's Avatar
Default Broken Pump
I have an 07 s2000 and behind the front bumber and just infront of the wheel there is a black electric pump, mine has shattered , do any of you know what it is for?
cheers
Old Dec 1, 2009 | 09:59 PM
nicks2k2000's Avatar
i believe that is an AIR pump used for emmisions or vaccum lines but not completely sure
Old Dec 2, 2009 | 12:22 PM
turbo_slug's Avatar
interesting...i thought ap2's didn't have an air pump?
Old Dec 2, 2009 | 12:27 PM
Slows2k's Avatar
06 and later US spec cars don't have a air pump. It could be a pump for the headlight washers on euro cars. The UK forum may have more info.
Moving to the UK forum.
Old Dec 2, 2009 | 12:35 PM
martin j's Avatar
Pictures.?
Old Dec 2, 2009 | 12:37 PM
chrisr111's Avatar
It's the air pump. All UK cars have one including later DBW cars.
Chris.
Old Dec 2, 2009 | 12:45 PM
Slows2k's Avatar
Not all S2k's are the same in all markets. Good to know
Old Dec 2, 2009 | 12:46 PM
s2konroids's Avatar
Chris.
Old Dec 3, 2009 | 02:19 AM
Is that all it is for, emissions? Would the pump be any reason for my car idiling fast, around 2000rpm? If it doenst do anything apart from sort emissions would it be fine to run around without one for a while?
cheers guys
Old Dec 3, 2009 | 08:32 AM
turbo_slug's Avatar
i'd pull the fuse to make sure it doesn't overheat the contactor/relay (39794-PCX-023)
there's a bulletin for melting airpumps that would also damage the contactor/relay...probably due to overloading...
