Building a Sub
Old Sep 25, 2013 | 02:35 AM
Squeak's Avatar
Default Building a Sub
I have a Sub with a built in AMP but it is too big for the boot (no surprise there)
Is there anyone here that could maybe modify the box making it smaller/custom fit and ideal for the S and still use all the components from the one I have?
Old Sep 25, 2013 | 04:25 AM
Wellwibb's Avatar
I can't see it being all that effective so far back with a bulkhead inbetween? Even if you did manage to get it in there. Plus, the box will be designed for optimum output through shape and size.
Once you mess around with it you will probably lose some quality.
The previous owner of my S had an enclosed shallow pioneer sub fitted behind the passenger seat and in my opinion it's as power full as a bigger sub would be right back in the boot space.
Will.
Old Sep 25, 2013 | 05:31 AM
jimmyb1978's Avatar
There's no issue with the sound travelling through to the cabin but the speaker you have may have a recommended minimum space requirement so check that prior to cutting it down
My box is custom fit to hug the drivers side part if the boot
Old Sep 25, 2013 | 08:02 AM
Squeak's Avatar
That is just what I want
Old Sep 25, 2013 | 10:00 AM
AquilaEagle's Avatar
Administrator
I've got one but it needs a separate amp.
If you know someone handy (UF?) you could borrow mine to take measurements, I think you'll struggle to get the built in amp in.
Old Sep 25, 2013 | 12:19 PM
jimmyb1978's Avatar
My amp is tucked away inside the spare wheel so nothing is on show apart from the sub
Old Sep 25, 2013 | 02:20 PM
lovegroova's Avatar
It may be possible to remove the amp and speaker from the existing box, build a new (smaller) box for the speaker and then install the amp above the fuel tank or inside the spare wheel, or even under/behind the passenger seat.
That's probably the bast way to go about it.
T-Smac
Sep 11, 2011 11:37 PM
mpease0603
Oct 9, 2008 08:05 AM
lukedon
Jun 26, 2007 08:19 AM
JAPCAB
Nov 22, 2005 07:16 AM
