Bulbs
Old Jan 15, 2016 | 11:45 AM
GeordieWaz's Avatar
Default Bulbs
Hi all, I have got a sidelight out and was wondering what would be the best replacement and how easy is it to replace?
Also I have a slight rip in the drivers side carpet just under the front seat, how much would a replacement carpet be for this?
Old Jan 15, 2016 | 02:49 PM
aliendoughnut's Avatar
Just replaced mine with LEDs I prefer the White look rather than the oem bulbs which look yellow but it's a personal thing. As for replacing the bulb it's a bit fiddly you need to turn the wheel so you.have access then undo 2 clips and pull back the liner...then spend 20 mins fumbling and swearing till you get the replacement bulb back in place
Old Jan 15, 2016 | 10:27 PM
imc27's Avatar
This is exactly right. Simply changing a sidelight bulb is stupidly difficult and fiddly. Most of the time you'll be working in braille.
Old Jan 15, 2016 | 11:43 PM
noodels's Avatar
Put Cree Bulbs in mine bit more £s, it is possible to do from under hood as I did
the split may conceal clips that were put in the crossmember
Old Jan 15, 2016 | 11:54 PM
Soggybottomboy's Avatar
Tip care of Uncle Fester which works a treat is to switch the lights on to check all is working before refitting bulb holder back into its position plus this light helps you see where it goes back.
Old Jan 16, 2016 | 04:01 AM
day and night shots of the led sidelights i fitted
Old Jan 18, 2016 | 01:10 AM
GeordieWaz's Avatar
Thanks guys, i will be going down the LED route as they are not much more expensive and give off a much better light
Old Jan 18, 2016 | 01:23 AM
Mr-T's Avatar
As mentioned, its a PITA to do, but possible. I managed to do mine from the engine side, but caused countless cuts and scratches on my arm and hands by going through a rather small cut-out on the side.
Good Luck
Opie Oils
UK & Ireland Traders Forum
Apr 7, 2015 01:46 AM
Moddiction
May 15, 2012 05:00 AM
SD_FLIP
Oct 15, 2009 10:09 PM
HGL1668
Aug 4, 2009 05:11 AM
DGBCDB
Dec 11, 2007 03:37 AM
